Need to cut rectangular hole in dash - suggestions? - JeepForum.com
post #1 of 16 Old 10-17-2010, 01:57 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
Anybody know of a way to cut a rectangular hole in a
CJ dash without messing up the paint, and having clean lines?
I don't want to take the dash off to do it...
Palmetto is offline
post #2 of 16 Old 10-17-2010, 02:56 PM
dtcohen
1980 CJ7
tape off the outline of your rectangle with some heavy masking tape
dtcohen is offline
post #3 of 16 Old 10-17-2010, 03:26 PM
keith460
Jeep. There's Only One
keith460's Avatar
I use an air cut off tool at work and at home for the very thing you want to do. If you have steady hands and nerves of steel, then it's easy to make straight cuts without damage to surrounding items that may be in the way.
3" Variable Speed Air Cutter
1984 CJ-7 Renegade
keith460 is offline
post #4 of 16 Old 10-17-2010, 03:58 PM
Hybrid Jeep
1976 CJ5
You could try a sheet metal nibbler.
I used to use these all the time when mounting switches and whatnot.. should work for a larger area.. just more time nibbling away...
Hybrid Jeep is offline
post #5 of 16 Old 10-17-2010, 04:10 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
Thanks for the replies!
I have a dremel that I can get a cutting wheel for, maybe that will work.
I have an aluminum dash and am inserting a 3 switch bracket to control my fan and whatever
else I come up with.. trying to get the bracket into the dash.
Palmetto is offline
post #6 of 16 Old 10-17-2010, 04:38 PM
southshore30
1982 CJ7
How big is the hole to be? probably pretty small for a switch bracket. As someone else said use masking tape on your dash. measure out and mark w a sharpie the cutouts. use a hole saw of the same diameter as the cutout dimensions. drill one hole or two next to each other then finish the corners with a small saw. Jig saw or a small recipricating air saw that uses jig saw type blades work really well for dash cutouts. My $.02
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #7 of 16 Old 10-17-2010, 04:46 PM
248107
Guest
1983 CJ7
You can also buy a knock out puller for sq holes.They are used by electrical panel builders.Pricey but a clean cut.
248107 is offline
post #8 of 16 Old 10-17-2010, 05:34 PM
BriansCJ
1994 XJ Cherokee
I would get a pack of reinforced wheels for the dremel and tape off and take your time.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #9 of 16 Old 10-17-2010, 05:52 PM
gojeepin
1983 CJ7
If it doesn't have to have perfectly "squared" corners, you can drill a hole at each corner and cut your straight line to the hole. That way your corner will be uniform and not overcut.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #10 of 16 Old 10-17-2010, 07:34 PM
h2ojeep
1978 CJ7
I have used my dremel with a cutting wheel for the same reason. It works good and is faster than you think. You will have to change disk often, and wear safety glasses, the disks often shatter.
I masked it off, drew my lines and used a steady hand to follow the lines with the cuttoff disk. I found it better to score the line, and make many shallow passes until you are through.
h2ojeep is offline
post #11 of 16 Old 10-18-2010, 03:41 AM
keith460
keith460's Avatar
That's the best advice when using a cutoff wheel. Make a shallow pass on your lines first instead of trying to plunge the cutting wheel through.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 16 Old 10-18-2010, 05:49 AM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
I appreciate all the help!
I will use my dremel.. since I have one and know how to use it.. Need to get a few cutting wheels and make sure to use safety glasses.
Thanks everybody!
Palmetto is offline
post #13 of 16 Old 10-18-2010, 08:53 AM
86JeepCJ7
Thanks everybody!
Harbor Freight (if you have one near you) sells diamond cutting discs for dremel moto tools, last a lot longer than the reinforced dremel discs, but you will need ear protection as well
86JeepCJ7 is offline
post #14 of 16 Old 10-18-2010, 09:05 AM
Wrangler11
Wrangler11's Avatar
I have the same air cut off tool, but it doesn't seem to work very well? You've been able happy with it?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #15 of 16 Old 10-18-2010, 12:36 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
What kind of compressor and size of air line are you using? Those cut-offs use a lot of air. 3/8" line is the smallest I'd ever put on an air compressor. I bought one of these ( 3 HP, 21 Gallon, 120 Volt 115 PSI Cast Iron Vertical Air Compressor ) and they had a 1/4" ball valve with the 1/4 quick-connect on it. Hooked up my 3/8 line, and my Matco impact gun couldn't even break any lug nuts loose. Removed the valve, put on a larger regulator, and now I can snap lugs off if I wanted to. Also keep it oiled - the oil helps seal the vanes to the sides of the motor, not just lube the bearings.
Rick
Cutlass327 is offline
cut , dash
help with selecting aftermarket guages for clock and tach hole in dash JKM3134 Jeep CJ Forum 0 01-13-2010 07:51 PM
Hole in dash, what to put in it's place? imafishingfred Jeep CJ Forum 15 09-06-2007 02:38 PM
hmm big hole in dash pad what to do? bjf498 Jeep CJ Forum 5 02-02-2005 04:47 PM
Something to fill the clock hole in dash? knowlwk@snowhill.com Jeep CJ Forum 6 12-22-2003 06:53 AM
Need a switch for my off road lights to fill hole in dash Jeep Daddy Jeep CJ Forum 3 11-30-2002 07:16 PM
