#1 | |
Need comments.....
Check out my new brake line. Is this a bad run or will it work? No heavy wheeling...she is just a beach cruiser.
The other picture is a tube that comes down from my carb into the top of my engine. It corroded away and is not really connected right now. What is it? My jeep ran with it like this.... Thanks!
#2 |
I would put it on the otherside. Your gas tank is going to hit it. Can't make out what the other one is.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed. |
#3 |
i would rerun it, no offense to you if you ran it but it looks horrible and will probably vibrate and crack anyway run in tight to the frame and secure it to the frame.
#4 |
Your body is probably going to be resting on it too. It will for sure when the body flexes on the frame. Run it the factory way. Brakes aren't something to cut corners on.
80 CJ5 in the process of a frame up resto 96% complete. The little stuff will kill me. On the back burner for college. |
#5 |
Sorry, bad angle
Hit the gas tank? Sorry, probably a bad angle and I have not drilled my rear mounts in the new crossmember we welded in. Here is a better view.
#6 |
What is the factory way???
#7 |
These were pre-cut lengths that were not really long enough. Will get some 3/16th's tomorrow and re-run. How should I run it????
#8 |
From the factory the line runs inside the rear crossmember like you started to, but it goes over to the frame rail and then runs forward inside the frame rail. It basically follows the same path as the fuel lines.
#9 |
Agree with previous posts, follow fuel routings (for the most part)...1" body lift makes for a little easier routing and tub clearance as well.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back.... |
#10 |
factor line runs about there
f
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad. |
#11 |
ahhhhh, I get it. Do I run my fuel lines along the same path??? Got hte idea on the carb too. Thanks for the pic BFJ....
#12 |
The way he drew in the red line is the correct way the brake lines originally follow except for the hole in the middle of the crossmember is where it is supposed to run through, but where you have it I wouldnt see a problem...
#13 |
Which engine? If it's 258 the return line runs the same route, and the actual fuel sending line runs on passenger frame rail. If your going V8 they both run up the drivers side.
#14 |
304, so both lines up the same side I guess.
#15 |
The metal tube going from carb into manifold is for drawing in heat I believe. from my understanding its to heat a coil that effects your fuel mixture (dont quote me). I sealed around mine with silicone becaue they just sit in the hole in the manifold. Not sure where youd get another. Hope I helped somewhat
Tim |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
