Need CJ Steering Column Upper Bearings - JeepForum.com
post #1 of 14 Old 05-06-2009, 12:02 PM Thread Starter
wirsima
1982 CJ7
Help!!! I've disassembled my 1981 tilt CJ steering column and need to replace the upper bearings. Based on my Parts catalog, it is a J320 8362 Bearing Assembly but I cannot seem to cross reference this part number to any replacement. Does anyone know where to source these bearings?
Finally, this thing was really tricky to get apart and I know assembly is going to be a lot harder, is there any a really good source assembly manual for the steering column other than my blurry parts book?
wirsima is offline
post #2 of 14 Old 05-06-2009, 12:20 PM
lgreve
1977 CJ7
try this website this company has a lot of great parts for jeeps so i would try here first
http://www.quadratec.com/products/pr...arts&submit=Go
Restoration = lots of $ & time thrown at the jeep. I know we all know this but it helps in the process to keep things in perspective.
____________________
CHRISTIAN JEEPER #230
lgreve is offline
post #3 of 14 Old 05-06-2009, 01:20 PM
CSP
It's a GM Saginaw column, so any GM vehicle of the same vintage probably uses the same bearings.
Look up the parts for a Chevy with a tilt column and you might get lucky.
I highly doubt if Quadratec will have column bearings. They aren't that great.
CSP is offline
post #4 of 14 Old 05-06-2009, 01:27 PM
CJ Chet
I used this:
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #5 of 14 Old 05-06-2009, 02:50 PM
lgreve
1977 CJ7
i just did a quick check and they DO have the lower bearings so i would think that they would have the upper bearings but i could be wrong if you are still having trouble finding them i would give them a call and see if they could help you
lgreve is offline
post #6 of 14 Old 05-06-2009, 04:03 PM
CJ Chet
Got my bearings from the local Autozone. They were able to cross-reference the OEM part#.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #7 of 14 Old 05-06-2009, 04:22 PM
Fjguercio
1978 CJ7
Might want to ck this thread for rebuild info you may not have thought of and other rebuild links.
http://www.jeepforum.com/forum/f8/tilt-steering-column-repair-rebuild-564821/
Fjguercio is offline
post #8 of 14 Old 05-06-2009, 08:43 PM
afgd1
i was told essentials have then i was also told my 84 cj has ford column
afgd1 is offline
post #9 of 14 Old 05-06-2009, 08:57 PM
PearlRiver
1978 CJ7
The best thing to do is pull the upper bearing from a 70's -80's GM product - pickups or whatever, they are plentiful - I got mine from a Monte Carlo. It's the exact bearing (they are all Saginaw products). I was hunting the upper bearing but couldn't find it anywhere from the usual parts suppliers. Found one through the local Jeep dealer for $35. Then while at the local Pull A Part the following weekend, I got the same bearing for $2 from the Monte Carlo and took the $35 one back to the dealer.
PearlRiver is offline
post #10 of 14 Old 09-15-2010, 05:02 PM
pktim23
I found a set at thejeep.com its turner 4wd parts company. I searched high and low. I finally went to the jeep dealer. A 200.00 qoute later I had the part number . Google sent me to those guys. The final cost with shipping was 46.00. A bit on pricey side,but it came with all the hardware to replace the locking mechanism plus upper and lower roller bearings for the top half of the colume.Now I am searching for the instuctions to replace them????? Thanks in advance .
pktim23 is offline
post #11 of 14 Old 09-15-2010, 08:32 PM
gwolff
1978 CJ7
Also try Ekler's corvette for parts and part numbers. Then google for best prices on the assembly.
gwolff is offline
post #12 of 14 Old 10-13-2010, 01:02 AM
twildt
1978 CJ5
1978 cj5
not a tilt steering column.
guys i screwed up, i ripped out my steering system from the steering gear to the steering wheel. after i re-assembled it i have a part left over. its a snap ring. there were two of them. the first one is just under the steering wheel holding on the lock disk or whatever. where does the second one go???
twildt is offline
post #13 of 14 Old 10-13-2010, 10:03 AM
WoodyHD
1983 CJ7
I found this one site when I was going through a similar problem with my column. Came across this site. Guy had pictures for step by step taking apart and reassembly down to the ball joint looking thing. Can't seem to find it though. If I come across it I'll get back to you.
WoodyHD is offline
post #14 of 14 Old 10-13-2010, 10:13 AM
twildt
1978 CJ5
Awesome! thats what i need is pics with reassembly!! if you find it that would be great!!
twildt is offline
Tilt steering column upper bearings needed! gbeaklr Jeep CJ Forum 25 09-19-2012 11:52 PM
upper bearing help column help codywhi Jeep CJ Forum 1 11-29-2009 05:53 AM
Upper Steering Column Bearings krazyzigzagger Jeep CJ Forum 3 11-28-2007 01:51 AM
Where can I find upper steering column bearings? supraman1990 Jeep CJ Forum 13 08-13-2007 03:23 PM
Steering column bearings jdb_us1 Jeep CJ Forum 3 01-10-2007 08:39 AM
