Need a body mount measurement on frame - JeepForum.com
post #1 of 3 Old 12-18-2014, 09:57 AM Thread Starter
Dborns
I'm needing the body mount measurements for the rear crossmember thats just in front of the gas tank. The two original holes were eaten away, so I had a few pieces of stock welded back in, and can't find the exact measurements anywhere. I measured where the captured nuts are in the tub, but those didn't land very close to where the original holes were.
If anyone has their tub off, and can take a measurement, I need from the top, front of the crossmember, back to the middle of the hole, and then from the side of the frame to the middle of the hole.
Thanks
Dborns is offline
post #2 of 3 Old 12-18-2014, 11:01 AM
keith460
Jeep. There's Only One
keith460's Avatar
You should always measure from a centerline. Find the middle of the frame at each end and use a chalk line to mark center on the entire length. Much more accurate that way.
They should be 31.26" apart or 794mm. (15.625" or 15-5/8" from centerline)
Look at 'K' in the frame drawing below for body mount #5.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 3 Old 12-19-2014, 05:02 PM Thread Starter
Dborns
I really wanted to get the tub back on the frame, so I could move onto the next project, so I didn't cut the holes for these mounts yet. My plan is to install the other body mounts so I know that everything is lined up, then I can work from under the frame and drill the holes. With the tub up off the frame the width of the rubber mounts, I'll have enough room to be able to see the bolts in the tub, and drill up from underneath the frame. The measurement of 31.26 you put in post #2 helps also, thanks!
Dborns is offline
