Need advise on knocking and stuttering! - JeepForum.com
post #1 of 5 Old 04-16-2012, 06:43 AM Thread Starter
DrG123
1981 CJ7
OK, so I'm driving in this morning after letting the old girl warm up. She is an 81 cj7 with a 4 banger.
After about 15 minutes at 55 mph, she starts loudly knocking and stuttering like she's not getting enough gas. I pull over, and it all goes away. The rest of the drive in she's perfectly happy.
I turn her off, and after 15 minutes she won't start. Starter is engaging, just won't turn over (as in no fuel)?
Oil pressure is good, temp is good. Oil level is fine. Put in new fuel filter 2 months ago.
What ya think? Water in the tank? Has new plugs as well.
Any help will be greatly appreciated!
Also has new thermostat.
Michael
DrG123 is offline
post #2 of 5 Old 04-16-2012, 09:58 AM Thread Starter
DrG123
1981 CJ7
Update, pulled the fuel filter, soaked with gas, changed it. Added sea foam.
Still won't start!
Interestingly, there is motor oil in the air cleaner assembly, probably from the breather which goes from the manifold cover to the air intake.
Hoping for some help here!
DrG123 is offline
post #3 of 5 Old 04-16-2012, 03:12 PM
pman
Have you confirmed that you have fuel and spark? Not intimately familiar with the 4 but checking for fuel to the carb and fire to the coil and plugs will get you going in the right direction.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #4 of 5 Old 04-16-2012, 08:08 PM Thread Starter
DrG123
1981 CJ7
Thanx. Plugs are getting juice, but no vacuum through the carb!
No milk in the oil or radiator, no white smoke out the back.
I'm thinking timing chain!
The horror. The horror! LOL
DrG123 is offline
post #5 of 5 Old 04-16-2012, 09:21 PM
CoAce
1977 CJ7
Easy to find out....IF you know what timing was at.
Turn engine to TDC compression 0+old timing.
With that set pop the dizzy cap and see where the rotor sits.
Lined up with #1 plug wire?
You could even use 0 just to see if it's close.
CoAce is offline
Stuttering Problem Koehner58 Jeep CJ Forum 4 04-13-2012 09:47 AM
Need advise JoeUSMC Jeep CJ Forum 9 03-15-2011 02:08 PM
Engine Stuttering wranglelife Jeep CJ Forum 2 03-15-2011 11:40 AM
CJ7 Stuttering on Right Turns? coach_rose Jeep CJ Forum 0 04-14-2010 08:08 PM
Stuttering 6 rodtriplett Jeep CJ Forum 8 04-04-2007 09:01 AM
