Need advice: What year CJ to start with - JeepForum.com
post #1 of 5 Old 10-13-2008, 09:49 PM Thread Starter
Cappicaper
1978 FSJ Wagoneer
Hello all,
I have been a FSJ guy for years and am going to build a CJ. I would like to do a spring over lift and have done quite a bit of reading on the "procedure." However, everything I read about is on Jeeps that are post 71 (I think the longer version?).
I have a line on a 63 CJ with a 302 in it. Stock running gear throughout. Should I be looking at this thing? Are the newer - post 71 or whatever - better prospects to work with?
Looking for advice - I have more time and inginuity than immediate cash so I don't mind doing the labor.
Thanks.
78 Wagoneer
63 CJ
Cappicaper is offline
post #2 of 5 Old 10-13-2008, 09:53 PM
trailridin4x4x4
1981 CJ7
i would look for a 82-86 cj7.
trailridin4x4x4 is offline
post #3 of 5 Old 10-13-2008, 10:04 PM
Renegade79
x2 on the later model CJ7. 76-86 has the best aftermarket support as far as replacement parts and accessories go. starting in 1980 jeep started using the Dana 300 transfer case which has a lower low range than its predecessor the Dana 20.
'06 Wrangler SE, soft top, hard doors, 2.4L, rolling completely stock and unmodified for the short term...
'10 Wrangler Sport, soft top, hard doors, 23S package, Teraflex 2.5" spring lift, Spidertrax 1.5" wheel spacers. Sold.
'79 CJ-7 Renegade, 258 I6, T150, D20, D30/AMC20, 2.5in Rancho lift, 31x10.5 AT's, TeamRush upgrade, flush tail lights - Sold :'(
Renegade79 is offline
post #4 of 5 Old 10-13-2008, 10:11 PM
1984CJ
1984CJ's Avatar
To me the 82 is the best year due to the combination of wide track axles, dana 300, behind the seat sport bar, newer hard door style, and lack of computer controlled carb.
82-86 is what has the best aftermarket support.
Unfortunately they also have the weakest transmissions (aside from the T176) and weaker locking hubs.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #5 of 5 Old 10-13-2008, 11:18 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
If you're going to 'build a CJ', go with the latest one you can find. My recommend would be a 1986 CJ7 or 1985 CJ8. Last years of production for both models. If you want a CJ5, then get the 78-1983 model. But I can't recommend a SOA on a CJ5 with stock NT axles. Even better: Get a custom frame from TDK that's set up for a TJ style suspension and 'build' your CJ from there.
"In the end...It's all Hack."
HackFabrication is offline
One Piece Axle-Advice for You--Advice for Me jpd1899 Jeep CJ Forum 4 12-11-2009 04:23 PM
Need advice on DJ5 151 ci that won't start in wet weather DJ5 Jeep CJ Forum 5 08-30-2008 07:57 PM
Confused, what year did AMC start using the ECM (computer) SlikRic Jeep CJ Forum 47 08-26-2008 10:52 AM
Slow to start advice... Raccroc Jeep CJ Forum 3 06-15-2008 02:43 PM
Need advice on Unseen Tranny (2 out of 5 is good start?) Floridazed Jeep CJ Forum 15 01-11-2008 10:11 AM
