Need advice running 3 fuel lines & brake line on driver side frame rail... - JeepForum.com
post #1 of 5 Old 08-21-2010, 09:57 PM Thread Starter
Aaroneous
1983 CJ7
I got my issues straightened out with inlinetube.com and I have all the right lines now. 3/8" send, and 5/16" return and vapor lines.
My CJ is an '83, so from the factory it had the fuel send line on the passenger side like most CJs, but I ordered a fuel line for a CJ with a factory 304, and I remembered after it got here that stock CJs with a 304 had the fuel send line on the drivers side. I'm a little nervous about proximity to the exhaust, but I can always put together a heat shield if I need to, I guess.
Has anyone tackled this on a rebuild that has a clever solution for bundling the fuel lines and attaching them to the frame? It's a little crowded over there... A pic would be extremely helpful!
Thanks!
Here's the current mess:
I've got some of these insulated clips (left) to attach a single line to the frame. Should I use a bunch of the "s" shaped clips to attach the lines to each other? Is that enough?
CJ7, AMC 360 Howell TBI, T-18a, d300, D44 front and rear, Stock YJ rear springs all around SOA and outboarded, BFG 33x12.50s, Warn XD9000i
Aaroneous is offline
post #2 of 5 Old 08-22-2010, 08:38 AM
ctm
You could look at pics of a YJ, they had all the lines on drivers side, and an OEM hard line that looped under the engine over to the fuel pump. that is why the CJ setup is better, but if need be you could follow the YJ setup.
ctm is offline
post #3 of 5 Old 08-22-2010, 09:06 AM Thread Starter
Aaroneous
1983 CJ7
Thanks for the tip on looking at YJ routing. That was really helpful... I found this:
http://www.jeepforum.com/forum/f12/m...ml#post9738563
Any idea where the best place is to look for those line clips?
post #4 of 5 Old 08-22-2010, 01:45 PM
ctm
ctm is offline
post #5 of 5 Old 08-22-2010, 03:44 PM Thread Starter
Aaroneous
1983 CJ7
Here's what I ended up doing. I used the insulated single line clips I had to attach everything on the drivers side... It's not beautiful, but it is all secure and it works for my purposes. I hope the e-brake cable will pass normally.
Running fuel lines in-frame - what have you done? Aaroneous Jeep CJ Forum 12 12-18-2009 09:50 AM
4.0L swap - Fuel Rail Line Routing 81jeeper Jeep CJ Forum 4 06-28-2009 01:40 PM
Running steel fuel line inside the frame rail chet44 Jeep CJ Forum 21 12-10-2008 07:27 AM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 06:01 PM
Running stainless fuel lines. Help!! bassfsr Jeep CJ Forum 5 06-26-2006 06:43 PM
