need advice! CJ engine/trans swap or build? - JeepForum.com
post #1 of 7 Old 10-07-2003, 10:13 PM Thread Starter
jcberm
ok, I have an 81 CJ 7 304 v8 auto trans w/ 1 piece moser in amc20 I do moderate wheeling, mostly desert sand or mountain trails. Here is my delima. My motor needs to be rebuilt so does carb, trans is slipping. I am thinking of swapping in a 258 w/ t55 tranny. I used to have a cj8 w/ that combo and it worked fine for me. Not sure how much horsepower I'm going to give up because the v8 never ran strong since I've had the jeep
.(bad rings)
Does any one have any suggestions, thoughts, Ideas Diiferent motor/trans thoughts for me?
oh yeah, running 33's w/ 3.73's Also looking at a locker in front d30. Thanx in advance!!!
jcberm is offline
post #2 of 7 Old 10-08-2003, 07:00 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I would keep the V-8, change over to EFI, and if auto replace the trans with a five speed, or just rebuild/replace the auto.
OK so I am a V-8 fan, The six is a good engine, if it is in good condition with a trans I guess it would be a viable solution.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #3 of 7 Old 10-08-2003, 11:16 AM
kjc2260
I agree with NnF on keeping the V8. I have the same engine in my '77 that I'm in the process of rebuilding. As far as power goes, here are the specs-1971-1990 258 150 hp@3800rpm, Torque 240 lb. ft.@1800 rpm vs. 1972-1991 AMC V8 150 hp @4200 rpm, torque 245 lb. ft. @2500 rpm. As you can see, they're pretty close and these are stock numbers. I'm just a V8 guy. If you decide to rebuild your V8, I have a brand new 2bl carb I'll sell you cheap. Also, as far as cost, I think you would come out better by fixing what you have and for sure a lot less hassle. Just my 2 cents worth. Good luck.
kjc2260 is offline
post #4 of 7 Old 10-08-2003, 10:45 PM
eight
eight's Avatar
I'd keep the V-8 and the auto. The auto and the high geared T176 were the only strong trannys put in jeeps with the d300 t-case. A 304/tf999/d300 sounds like the start of a good drive train to me.
eight is offline
post #5 of 7 Old 04-19-2016, 03:55 PM
Deadmanshouse
Yes, you should try to rebuild the v8 and do some 4x wheeling at the behind the Fairways in PS.
Deadmanshouse is offline
post #6 of 7 Old 04-19-2016, 11:14 PM
AllenForaker
1975 CJ5
If you think your drive train has all of these issues, start with just one of them. Do a pressure check on each cylinder first, if they are withing spec, then go to step 2. A carburetor rebuild is much cheaper than replacing an engine/transmission, cheap and easy. If the last two items check out and you still think its the transmission, drop it and take it to a respectable service center and let them inspect/repair as needed, still cheaper than replacing the whole power train. With patient/diligent diagnosis, you can find where the problem lies without changing your whole power train. A V-8 w/automatic is a great combination for wheeling, try to keep what you have.
AllenForaker is offline
post #7 of 7 Old 04-20-2016, 02:41 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Those numbers aren't a accurate comparison. The 258 numbers you listed are gross numbers. The 304 numbers are net.
The apples to apples net numbers for 1981 are:
258 - 110 HP @ 3500 RPM
304 - 125 HP @ 3200 RPM
Matt
Matt1981CJ7 is offline
Engine/Trans/Xfercase Options for my Build Poll motiv8ya Jeep CJ Forum 3 03-06-2009 07:59 PM
CJ7 Engine Swap any advice? sdozzi Jeep CJ Forum 0 02-11-2009 01:08 PM
Noob engine/trans swap questions Cheap-o-Jeep Jeep CJ Forum 6 01-18-2009 09:35 PM
Engine and trans swap list CrazyHorse6 Jeep CJ Forum 8 01-04-2009 02:55 PM
258 Engine Swap Out Advice SHANKLM Jeep CJ Forum 2 07-20-2008 10:21 AM
