Need advice - '76 CJ5 Engine/tranny swap - JeepForum.com
post #1 of 7 Old 06-20-2002, 12:35 PM Thread Starter
dixiediesel
Question Need advice - '76 CJ5 Engine/tranny swap
I have a '76 CJ5 with a 304 and 3 speed tranny. I have heard that a Ford 302 will drop right in. True?
My 1st gear synchronizer is shot, so rather than fixing it, I would like to go with a 4 speed.
Considering that I would like to go with the Ford 302, what tranny would you recommend? Can I keep the T-150? What about my transfer case? I am going to do all the work myself, so I'm looking for an answer that is fairly simple, as in not having to change out the whole drive train or welding new motor mounts etc.
Thanks for your time in replying.
1976 CJ-5; 304ci, bare bones.
dixiediesel is offline
post #2 of 7 Old 06-21-2002, 07:49 PM
buddhasbomb
Red face
what is it with some people.they buy a Jeep and want to put some other motor/trans combo in.the 304 is a better motor than the 302 and its fairly easy to find a 4 speed to go in the thing.
buddhasbomb is offline
post #3 of 7 Old 06-24-2002, 01:35 PM Thread Starter
dixiediesel
Post
It's not that I don't like the 304, it's just that it's such a hassle to get parts, and there are no aftermarket parts.
post #4 of 7 Old 06-26-2002, 09:11 AM
LS1CJ5
1979 CJ5
Post
The 302 was my first choice also. 1st reason, you can keep your trans. The T150 has the same bolt pattern as the T5 that's behind the FI302. If you want to put your CJ on a serious diet then a 302 is the way to go. Compaired to the all cast iron 304. Oh, it has an aluminium front cover. That's because in the Day, they couldn't cast that thin of iron and have it last. My intake was about 60lb. Then the other major plus. Fuel Injection,, crank and run no matter how ruff or steep the grade. I liked the 304 when I had it but the 360's up have the heads that Flow,, so you don't have to shift at 4500. I got 500 for it. If you don't want to cry then don't look at the HP ratings on those 304's. From 72-81 you have 125 to 130, Torque 220-245, 2bbl & "off-road.com" numbers. To make it worst don't go look at the HP of a stock Civic si. I bought a 99 Corvette LS1. It Idles perfect and Flys. all at 425lbs.
1979 CJ5 LS1, NV4500
LS1CJ5 is offline
post #5 of 7 Old 06-26-2002, 03:44 PM
buddhasbomb
Lightbulb
youve just gotta look and you will find.by the way AMC/Jeep was famous for underrating their motors.
post #6 of 7 Old 06-26-2002, 07:29 PM
cjdriver
cjdriver's Avatar
Post
You sure can put a 302 in there, unfortunately I dont know what combinations of stuff will work. Try <a href="http://www.advanceadapters.com," target="_blank">www.advanceadapters.com,</a> they should be able to help you with everything.
As for the 304, it will never be as easy to modify as the 302 but is not a bad engine at all. You can find headers and quite a few other things for them to fix them up and they make a great engine. You might want to consider just saving the money for conversion and put it toward something else.
But, if you want the 302 go for it. There is no real reason you shouldnt if thats what you want. After all, Jeeps are to have fun and to make our own unique rides, so do it up and dont forget to show us pics when you are done.
Jim Sykes
motorsports photography
cjdriver is offline
post #7 of 7 Old 06-28-2002, 12:57 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
304s were NOT rated at 125-130! They were "rated" at 150HP, but I can tell you that ratings dont matter.
What was rated at 150HP 30 years ago is much more powerful than what is rated at 150HP today. There are so many variables to HP/Torque Ratings, that you can play with the #s any way you want! These days, the numbers are way off the wall, and it is all for marketing, so people will get a hard-on for the #s and buy the vehicle.
I have a '72 bone stock 360 AMC in my '77 CJ, with a 2-bbl. It has a factory "rating" of 175HP, but I can tell you it'll blow the doors off my '96 XJ with a 4.0L & 190HP "rating".
By the way, how the hell can you even compare a civic? They have menial HP, and NO Torque. HP alone is nothing. You'll find that the AMC motors are a very hefty, durable motor, and offers very respectable torque.
I don't care what people use, personally, but I will always stick with AMC motors, because I love them and it saves a lot of swap Bull****. They are almost completely interchangeable thru the years.
4wheeler4CJ is offline
CJ7 Engine Swap any advice? sdozzi Jeep CJ Forum 0 02-11-2009 01:08 PM
258 Engine Swap Out Advice SHANKLM Jeep CJ Forum 2 07-20-2008 10:21 AM
Need advice on tranny swap msheffield Jeep CJ Forum 1 11-18-2007 12:02 PM
CJ5 to CJ7 Engine and Tranny swap? fluid_grind Jeep CJ Forum 2 02-06-2007 07:35 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
