need advice - Page 2 - JeepForum.com
post #16 of 22 Old 05-15-2013, 09:53 PM
RIPNBST
It's a good idea to re weld if you know what you are doing with a welder. If you plan to drive this thing daily on the road and have never driven a welded diff vehicle before prepare yourself for altering your driving style.
Be prepared to replace your tires WAY sooner than you wanted to as well.
RIPNBST is offline
post #17 of 22 Old 05-15-2013, 10:17 PM Thread Starter
Newbjeep
1972 CJ5
Yeah I am a good welder but instead of re-welding it I am gonna take this opportunity to convince my wife it's un fixable and go and get a limited slip put it I found a friend of a friend that can do it for 700 including parts and labor an I know he's good he has his own shop and builds rear ends for street and strip cars. Oh and I decided on a limited slip in rear because I will be on the road at least half of the time and don't wanna burn thru tires super fast
Newbjeep is offline
post #18 of 22 Old 05-16-2013, 08:45 AM
scrappycj5
1976 CJ5
You can get a powertrax locker which is limited slip, for around $400 and maybe even cheaper. This friend of a friend is charging you too much. You can do it yourself, pretty easy and it will replace the damaged spiders in your dana 44.
As far as welded spiders go, if its a crappy weld and pcs of the weld fall off while driving it will grenade everything in the housing. So make sure everything is tight. Driving around on welded spiders is an advanture going around corners especially. Be very careful on wet roads.
scrappycj5 is offline
post #19 of 22 Old 05-16-2013, 05:54 PM Thread Starter
Newbjeep
1972 CJ5
I really like the sound of that and the reviews arent bad at all I'm gonna try it thank you now ill be able to get her back on the road shortly
Newbjeep is offline
post #20 of 22 Old 05-17-2013, 09:41 AM
jsipe007
Good luck and sorry to hear the PO lied about the Detroit locker. Did you ever find what ratio you have? often it is stamped on the ring gear itself so that is an option as well.
700 for limited slip is too much as stated before me. You can do an elocker for almost that price. I have also heard good things about the Detroit True Trac.
jsipe007 is offline
post #21 of 22 Old 05-17-2013, 01:25 PM
SLO_Ken
See his other thread here.
SLO_Ken is offline
post #22 of 22 Old 05-19-2013, 09:25 PM
jsipe007
Thanks for the link!
jsipe007 is offline
