Need 1980 CJ5 Stock Shackles front and rear - JeepForum.com
post #1 of 4 Old 03-13-2002, 08:48 PM Thread Starter
scottahicks
scottahicks's Avatar
Post Need 1980 CJ5 Stock Shackles front and rear
Hey I have a serious problem,, I just got my first jeep 1980 cj5 304 V8 ,, and unfortunatly I bought a nightmare under the impression it was it great shape. anyway I need a full set of stock shackles, CHEAP!!!! I am being eaten alive with trying to fix all thease problems and one is the realy bad realy long shackle lift that is making my poor jeep eat u joints,,,, on my 3rd ujoint in 3 weeks yes its that bad, i dont know how this guy drove this thing regularly anyways PLEASE someone help me im desperate,, this is my daily driver and ONLY vehicle now
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #2 of 4 Old 03-13-2002, 10:09 PM
HighCountry
Post
Hey, I feel your pain! I always can find things wrong with any vehicle, even a NEW one on the dealers lot...
As for a quick shackle fix, just drill a new set of holes in one end of your long ones. I am not sure what the distance from hole to hole is, but if you need to know someone can run out and measure a set on their Jeep!
And as for U-joints, they are NOT all created equal! Go to NAPA and ask for their "Heavy Duty" version, or if you can find a "Spicer" dealer buy one of theirs.
Good luck!
Bruce
HighCountry is offline
post #3 of 4 Old 03-17-2002, 12:30 AM Thread Starter
scottahicks
Unhappy
thanks for the idea but the lift shackles on mine have multiple cross bar supports that prohibit that idea
post #4 of 4 Old 03-17-2002, 10:42 PM Thread Starter
scottahicks
Post
Problem solved ,, and would you belive I solved it with new lift shackles???? ok heres what I did I went to pep boys and found a generic shackle lift kit like for a hot rod, there are four holes in each shackle plate one intended as the main and 3 on the botom to adjust as you choose your ride height,, and wouldent you know it the spacing between the outer two of the botom 3 is exactly the same as a stock jeep shackle, and the entire length of the whole shacle is well ove double that,, so the soloution ,, buy one shackle kit for 15.00 and go home, cut the shackles in half with the angle grinder you just have to have if you have a jeep, copy the bolt holes on the halfs that end up with only one hole with a 1/2 in drill bit and NOW you have a total of 4 complete shackles because you use the center hole and the bolts they give you in the kit as a stabalizer bar for the shackle,, it was a little work but 15.00 and my problem is solved
What is the difference in the front and rear shackles bigpapa18205 Jeep CJ Forum 4 11-01-2009 10:39 AM
length of stock shackles on 1980 cj7 sardis22 Jeep CJ Forum 2 06-11-2009 11:19 PM
Will 33's fit a stock 1980 CJ5? jmerlick Jeep CJ Forum 6 04-26-2005 01:52 PM
Need stock rear shackles twmattox Jeep CJ Forum 2 02-08-2005 03:01 PM
1983 CJ7 OEM Shackles Front and Rear, same size?? fLeXyJeEp Jeep CJ Forum 1 04-14-2002 07:47 AM
