Narrow or WideTrack - JeepForum.com
post #1 of 14 Old 01-20-2010, 09:30 AM Thread Starter
SwampRabbit
Narrow or WideTrack
I have a 84 CJ7 with the wide track under it with 3.?? gears. I have just bought a set of narrow track axles with 4.56's and detroits in them. It would be alot easire for me to just put the narrow track under my jeep. Or i could take the gears and lockers out and put in mine. How bout some suggestions.
SwampRabbit is offline
post #2 of 14 Old 01-20-2010, 11:12 AM
Ronzi
1983 CJ8
Sounds like youve answered your own question. It would be easier to swap axles but better to keep the wide tracks and transfer for the parts over. What size tires do you have to need 4.56's? You might consider selling both sets of axles and buying a bigger set.
Ronzi is offline
post #3 of 14 Old 01-20-2010, 11:14 AM
jatepper
Go with wide track or upgrade your axle
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #4 of 14 Old 01-20-2010, 11:35 AM Thread Starter
SwampRabbit
I"m running a 33x15.50. I believe i will be fine after i put the one piece axles in the rear and put on wheel spacers. Does having the narrow track really make a big difference when driving on the road?
post #5 of 14 Old 01-20-2010, 12:04 PM
stilesg57
1979 CJ7
Short answer: YES!
I was reluctant at first, but swapped my narrows to wide track last year and was amazed at the difference. With only 5" additional axle length, the handling at both highway and trail speeds is remarkable ('79 CJ-7, 4" lift, 33x12.5 ProComps). Good luck!
stilesg57 is offline
post #6 of 14 Old 01-20-2010, 01:05 PM
_Kyle_
_Kyle_'s Avatar
Wide tracks make a world of difference when driving on the road. I would probably sell both sets and find a set of wide tracks with the gears you want or buy bigger axles. This is unless you are capable of swapping gears in your own garage.
Or go narrow and buy spacers.
But with 456s, you've gotta be running some big tires.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #7 of 14 Old 01-20-2010, 04:04 PM
ReconRabbit
1983 CJ7
I vote the narrow tracs with spacers. I have run both on the same jeep and didn't notice a difference. Iirc its only a 3 inch width difference total
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #8 of 14 Old 01-21-2010, 08:04 AM Thread Starter
SwampRabbit
So it would be alright to just get 4 2in. wheel spacers and roll on? I've seen 3 inch wheel spacers for sale but that just seems too much. Also i will have to look at how much space would be between my tire and leaf spring since i'm running a 15.50 wide tire. How much more narrow is the NT vs. the WT?
84 Cj7:258ci;4 Speed;2 1/2 lifted springs;2in. Boomerang shackles;33x15.50x15 Super Swamper SX'sRamsey 6000lb. Winch
post #9 of 14 Old 01-21-2010, 08:45 AM
black954
1978 CJ7
I would swap axles first and see how you like it, then you can add spacers if needed. With 15.5" wide tires, I wouldn't think you would need anymore width.
black954 is offline
post #10 of 14 Old 01-21-2010, 09:17 AM Thread Starter
SwampRabbit
But with the narrow track axles i believe my tires would hit my leaf springs when turning and flexing. thats why i need the spacers i think
post #11 of 14 Old 01-21-2010, 10:17 AM
19jeep78
1978 CJ5
i'm running narrow tracks with 2.5" bs wheels. it drives fine. its going to cost you a good bit of money to take the guts out and put in your axles unless you can do it yourself. then you're probably going to want to do bearings and seals anyway. throw some spacers on and go.
1978 CJ5
SOA, 1"BL,stock springs, 35x14.5" boggers, BUILT 258/T-18/D20 twinsticked/D30/AMC20
1977 Scout II. 345v8/727/d20/44s. stock...for now
The tow rig:
99 Dodge 2500 cummins on 37s
19jeep78 is offline
post #12 of 14 Old 01-21-2010, 11:15 AM
MSBXCJ
1982 CJ7
How do I tell If I have wide track? I have an 82 CJ7 Laredo...
MSBXCJ is offline
post #13 of 14 Old 01-21-2010, 11:15 AM Thread Starter
SwampRabbit
Ok. I was planning on doing the gear swapping myself...but i found some 2.5in. spacers for $75 a pair. So i may just get them and try it. Thanks for the Info...
post #14 of 14 Old 01-21-2010, 02:31 PM
black954
1978 CJ7
thats why you swap em in and just see how it is, then if you find in necessary, install the spacers.
black954 is offline
86 CJ for Donor: Is this a D44 widetrack??? Johnyakimo1855 Jeep CJ Forum 7 05-31-2009 08:27 PM
75 widetrack vmaxup Jeep CJ Forum 10 01-14-2009 01:11 PM
Widetrack/ Narrow jeepfreak456 Jeep CJ Forum 4 02-20-2008 01:40 AM
82 Widetrack or Narrow Track...How to Tell? KSToyz Jeep CJ Forum 7 09-28-2007 02:09 PM
widetrack VS Narrowtrack?? Goondock Jeep CJ Forum 13 06-12-2006 10:37 AM
