mystery squeak under load - JeepForum.com
post #1 of 3 Old 04-25-2009, 09:19 AM Thread Starter
GAchoptop
GAchoptop's Avatar
1977 CJ7
Need a little help here - don't want to go replacing stuff until it's fixed. Here's the problem - I get a squeak whenever I make my 77 CJ go using the engine, in other words when coasting or braking it doesn't squeak (its an automatic;q-trak). Seems to be speed related (pitch changes with speed though when I get past 45 can't hear it most likely because of road noise) Can't really tell where its coming from at first I thought bearings (even though braking didn't make the squeak go away) so re packed just to make sure. no help. now thinking u-joints-- but before replacing all four and two in the axle wanted to get some suggestions of other things it might be or how to narrow it down to which u-joint. any suggestions?
GAchoptop is offline
post #2 of 3 Old 04-25-2009, 10:33 AM
heepzilla
If you dont have the hubs locked in and it makes this noise it has to be the rear drive shaft.
05 Rubicon Unlimited. 09 Husaberg FE 570
heepzilla is offline
post #3 of 3 Old 04-25-2009, 11:12 AM Thread Starter
GAchoptop
GAchoptop's Avatar
1977 CJ7
'preciate the fast reply - it's full time 4-wheel drive Q-Trak transfer case. No hubs and from what I understand I'll kill the cones in the Q-trak if I remove either drive shaft and try to run in 2-wheel.
Mystery Part steveracer67 Jeep CJ Forum 5 01-08-2008 04:56 PM
Mystery Carb? ollietonk Jeep CJ Forum 2 11-30-2006 05:31 PM
mystery noise brak Jeep CJ Forum 9 07-17-2006 03:57 AM
Mystery wire? NYScrambler Jeep CJ Forum 2 05-19-2005 04:51 PM
"standard Load" vs "C" load tires on CJ only in a jeep cj Jeep CJ Forum 1 02-19-2003 11:47 AM
