Mysterious Shutoff!!! - JeepForum.com
post #1 of 29 Old 04-21-2010, 07:18 AM Thread Starter
jeeperscrepers
1979 CJ7
Ok, I have replaced the Resistor, Distributor Cap, Rotor Button, Plugs, Ignition Coil, and Starter Selinoid. What am I missing??? Next, I am planning on taking it to my mechanic and having him replace the pick-up in the distributor. I am at a loss as to why I continue having this shut-off problem. I will be going down the road and it just shuts off and starts right back up. Does this at idle as well as under way.
My jeep is a 79 CJ7 with an In-line 6, 258 engine. Anyone else had this problem and found the issue or any one that can offer anymore suggestions as to where to look?
jeeperscrepers is offline
post #2 of 29 Old 04-21-2010, 08:02 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
I had the same issue when I first got my CJ, it turns out in the wire harness just above the steering collum there was a wire that had been cut and was exposed, when you hit a bump, the offending wire would ground against the firewall and kill the engine. The way I found it was pure luck, I turned the shop lights out after working on it for a few hours and was headed out the door, I walked past the jeep on my way out and started it once more (don't know why, I just did) as it started to idle I stepped out of it and moved the JEEP just enough to see a flash from up front and it died. I called the wife into the shop and had her start it, I rocked it really hard and sure enough I saw the flash again. I found the wire and capped it and it hasn't done it since.
Good luck on yours.
Tom
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #3 of 29 Old 05-13-2010, 07:29 AM Thread Starter
jeeperscrepers
1979 CJ7
Ok, about three weeks ago replaced the Distributor and it seemed to have fixed my shutoff problem. But, Sunday, Mother's Day, it reared its ugly head again. I am at a loss, could it just be that the distributor pick-up went bad in the new distributor? I am guessing a lose wire, bad wire, ignition mod...I don't know...but it is driving me NUTS!!!!!!!!!!!
post #4 of 29 Old 05-13-2010, 07:43 AM
Dislsmoke
I had that problem with my 258, the ignition module would overheat and the jeep would shut off, after it was cool it would start up again. I would try the ignition module on the fender, I think there are a bunch of write ups on it. But I also kept having problems after that with new modules. Finally just went to a HEI, but that is a whole different topic.
85' CJ-7, 258, T-5, D-300. Soon to be 360, t-18,d-20
4" skyjacker, 33's, frame up resto, Custom built everything else.
Custom Dashs built to your specs
website.
Dislsmoke is offline
post #5 of 29 Old 05-13-2010, 10:32 PM
OldSkull
1980 CJ7
I had the same thing. It would die and start up fast enough to churp the tires. It was the wire to the tachometer. since it is in line with the ignition somehow, it was just loose enough to die and restart on the slightest bump. I had the cover off the steering column one day and squeesed the wire connector as I was driving just for the hell of it and ...that was it. Got lots of new (unneeded)parts out of that one.
304 - T176 - D300 - D30 - M20 - 4" Superlift - 35-13.5x15 Krawler T/A's - TJ Flares - Team Rush - MSD 6A - Cavalier Seats
OldSkull is offline
post #6 of 29 Old 05-14-2010, 08:09 AM
Trapshooter
Intermittent electrical problems are some of the hardest to troubleshoot. You need to trace out the ignition power & groiund circuits in an attempt to find the intermittent open in the system. As described in the previous posts you most likely have a loose power or ground connection.
Try to gain easy access to the circuits and start moving things while the engine is running.
Good Luck...........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #7 of 29 Old 05-14-2010, 01:06 PM
Mike Romain
A bad ignition module will give those symptoms.
Mike
Mike Romain is offline
post #8 of 29 Old 05-14-2010, 01:48 PM
OldSkull
1980 CJ7
Mike,
Have you had any experience with a module that tested good at the parts store but still caused intermittent problems? I have similar issues.
I was going to suggest the OP get his module tested, but it might not matter if it tested okay anyway, right?
OldSkull is offline
post #9 of 29 Old 05-14-2010, 01:54 PM
Mike Romain
Originally Posted by OldSkull View Post
Mike,
Yes, many times. They work fine until they reach a certain temperature, then they up and die. I have seen quite a few brand new out of the box do this also. Wells brand ones come more often dead out of the box than working.
Mike
post #10 of 29 Old 05-14-2010, 06:30 PM
Torxhead
I believe the N.A.P.A. Echlin brand makes the best ICM. Its always nice to have a spare, even with an H.E.I. The good stuff always comes with a matching price tag. Just like the MSD ignition. Ground out the black wire coming from the ICM, it will last longer.
Torxhead is offline
post #11 of 29 Old 05-17-2010, 08:07 AM Thread Starter
jeeperscrepers
1979 CJ7
Thanks! I had the ignition mod tested and the guy tested over and over to heat it up with each test passing. BUT! Could it be this simple??? I decided to change the gas cap because the rubber gasket had dried out a bit and torn. This was Saturday and it hasn't done it since, not saying it is fixed but I will take the two days of running seemlessly!
post #12 of 29 Old 05-17-2010, 08:35 AM
Jeepican
1976 CJ5
Mine was my PO installed Electric fuel pump.... I switched everything back to manual and have had no trouble since....
I let it idle in the driveway until it finally shut off then pulled my gas line into a bucket and no gas.....
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #13 of 29 Old 05-18-2010, 05:22 AM
Mike Romain
The gas tank does need to be vented. The vent is the charcoal canister and it has a $2.00 air filter on it's bottom that when plugged with dirt puts a vacuum on the gas tank which will cause stalls and bogs. Not usually at idle though.
Mike
post #14 of 29 Old 05-18-2010, 05:25 AM
Mike Romain
The CJ rubber gas lines that connect the tank and pump up to the steel lines go 'bad' in the modern mix they call gas these days. They crack and can let the line vaporlock. It is a suction line so it doesn't usually drip on the ground, it just leaves a stain on the line so a good visual check is in order.
Mike
post #15 of 29 Old 05-21-2010, 07:51 AM
AlbertGaines
1980 CJ7
I also have been having ignition (I think) shutoff issues. Shuts off after running for some time. Starts off with a small hickup then gets worse and will shut off. Can restart after some effort and may run fine for a few minutes. Will not show problems in the driveway after getting it home and trying to find the issue.
After it cools off it will start and not show any signs of the problem until some period of driving time.
Acts like Ignition Module.
I have replaced the Iginition Module 3 times, Coil, ignition switch, manual fuel pump, put in a new distributor last night. I hope it is the pickup getting hot and maybe being saturated and sending a bad signal back to the IGM.
The pickup was $20 the rebuilt distributor was $60, so I replaced entire distributor.
Keeping fingers crossed.
AlbertGaines is offline
dies , electrical , shut off
Mysterious button by the clutch. Aduffy32 Jeep CJ Forum 83 10-30-2009 10:28 PM
Mysterious Battery Drain? feetdoc1 Jeep CJ Forum 15 03-19-2009 08:53 AM
Mysterious 258 sweetguardian00 Jeep CJ Forum 12 09-08-2008 08:13 PM
Mysterious vacuum leak Kerberos Jeep CJ Forum 2 08-06-2008 08:42 PM
Mysterious holes in my frame Reno_CJ7 Jeep CJ Forum 3 04-14-2004 02:07 AM
