My windshield wipers suck - JeepForum.com
post #1 of 13 Old 10-05-2013, 12:14 PM Thread Starter
wsmutch
I drove home from work this morning in a downpour. My windshield wipers work, and go fast enough but it highway speed the arms don't put enough pressure against the glass. The blades are new out of the box less that three months. I pulled the arms off, and it seems to me the springs are worn. Anyone try changing the springs? If so, where did you find them?
wsmutch is offline
post #2 of 13 Old 10-05-2013, 12:23 PM
Spieg8
1984 CJ8
CJ wipers are notorious for poor performance. The aerodynamics (or lack of) tend to push the wiper arms all over the place at highway speeds. You can buy replacement arms with new springs and it may help some, but they're never going to be great. Best upgrade I've found for a CJ are these (you can actually use regular wiper blades with these too);
http://riptech.net/cgi-bin/ps.cgi?AC..._ID=2861437840
Spieg8 is offline
post #3 of 13 Old 10-05-2013, 04:06 PM
skizriz
1978 CJ7
I run 13" Anco blades on mine. I cut the hook off the ends of my wiper arms, and epoxied the clips for the Anco blades on.
They clean the entire windshield now.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #4 of 13 Old 10-05-2013, 05:29 PM Thread Starter
wsmutch
Wow, almost $200.00... I was hoping to replace a few 20 cent springs.
wsmutch is offline
post #5 of 13 Old 10-05-2013, 06:35 PM
JustDandee
1983 CJ7
Some manufactures use an air deflector to apply more pressure on the glass like this...
http://www.spoonworld.com/miata2/my94-wiper1.jpg
Maybe you can give that a whirl?
JustDandee is offline
post #6 of 13 Old 10-05-2013, 09:59 PM
LeePrather
1978 CJ5
That's insane cost just for the linkage, the arms and the blades...
LeePrather is offline
post #7 of 13 Old 10-05-2013, 10:08 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.4wd.com/search.aspx?PN=1&kw=Sure+Wipe
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 13 Old 10-06-2013, 06:56 AM
holliewood61
1981 CJ7
I went to napa they have a cabinet full of springs in the back. I found something close and had to cut a couple coils off of it to get good tension but it was a fix for under a buck.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #9 of 13 Old 10-06-2013, 07:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
FWIW, folding your windshield down without removing the wiper blades will stretch the springs.
Max, thanks for that link!! I wasn't aware a tensioner existed. I just ordered a set.
Matt
Matt1981CJ7 is online now
post #10 of 13 Old 10-06-2013, 08:47 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Matt
No worries Matt, glad to help!
I installed a set on an '82 CJ7 for my buddy and they made a world of difference!
Max
Mean Max is offline
post #11 of 13 Old 10-06-2013, 09:49 AM
PERK
I use the sure wipe springs also. seems to help
PERK is offline
post #12 of 13 Old 10-06-2013, 07:04 PM
WindKnot
1977 CJ7
Add me to the list too!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #13 of 13 Old 10-07-2013, 04:58 AM
CJ7VFR
I also use the Sure Wipe helper springs.
I bougth mine about 15 years ago, and they still look brand new. They are made of
stainless steel, and they do an excellent job of adding just the right amount of
pressure to the wiper arms.
They also look like they belong on a Jeep. I don't know what it is, but they just
look like they were there from day one.
Here is what they look like on my 1985 CJ-7:
CJ7VFR is offline
