My sister's CJ-5 Ressurection - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My sister's CJ-5 Ressurection
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-06-2014, 02:25 PM   #1
JayCJ5
1974 CJ5
Hello All, my first post.
A short bit of background. I grew up around Jeeps most of my life and I currently have a 73 CJ-5 in perpetual restoration. I'll save that for another day.
Without getting all maudlin, my father passed away about a year ago. He always had jeeps including a CJ-6 and a CJ-5. His favorite place in Colorado was Mosquito Pass. He spent a ton of time there both in the summer and winter with his jeeps.
From my trip this fall (with his favorite hat):
My sister had been continuously bugging me to finish my jeep and give it to her. Fat chance of that happening I kept my eye on Craig's list and recently saw a 74 CJ-5 for sale, "make an offer". The only information we had was it wouldn't start. I told her to make him a small offer and see if he would take it. I would provide the labor to bring it back to life. About a day later, this showed up in my driveway (the Jeep, not the Lab, she is always there):
It was even my dad's favorite color.
The first day I went through the whole thing. Whoever had it before had done some work - new brakes, new lines, new steering box, differentials serviced, etc. It had a bit of surface rust in places but overall was very solid. I thought this would be a breeze. Hah!
If you turned the key, everything came on and it would kind of crank, but just one little lunge. I pulled the battery and the starter figuring they would be the basic culprits. No joy, it still would not crank.
I pulled the grill off to get a breaker bar on the crank pulley and see if the engine would turn. Dang, locked up solid. This was going to be more work than I thought.
The next step was pulling the motor:
Looked pretty clean. It looked like someone had rebuilt it before (new intake manifold, valve covers, oil pan cover). I started the walk around inspection and what did I find?
Hmm... that can't be good.
More joy:
This is really starting to look bad.
Continue tearing down the motor and more smoking guns:
Pretty sure #7 push rod should be straight.
#4 lifter shouldn't look like that.
Bottom end coming apart:
Crank damaged
Finally the culprit:
I'm almost positive the cam should be one piece
Finally, damage to the #7 and #8 cylinders.
Well, guess this engine is toast. I don't know what happened first, but the cam was in three pieces, lobes on the crank are all scarred up, the #8 connecting rod was shattered, #7 and #8 cylinder walls damaged, etc. It must have scared the heck out of the guy when it let go.
So I am off on the journey to find a re-manufactured 304 long block or at least a new engine block to start with. Anyone have any suggestions in the Denver area? I would settle for a good block to start from, but would prefer a long block. I have been reading the suggestions in other areas of the forum and starting to do research.
I'm sure I will have additional questions as I go and will keep up the notes. This is not going to be a full restoration, but basically getting back on the road for summer fun and mountain passes.
jay
JayCJ5 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 03:24 PM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hi Jay, and welcome to the forum.
Here's a 304 in Loveland. Owner claims it runs and doesn't smoke. Price is right.
Here's another in Westminster that sounds a little iffy.
Good luck, neighbor.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 04:02 PM   #3
FLynes
FLynes's Avatar
1976 CJ5
Can the 304 be re-sleeved? If it can, you might look into that option too.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 04:17 PM   #4
seabass1858
1983 CJ7
X2. i know the 258 can for sure.
[URL="http://www.jeepforum.com/forum/f8/early-cj5-1960-willys-resurection-build-thread-2013737/#post19557889"]1960 cj5 willys f134[/URL]
[URL="http://www.jeepforum.com/forum/f8/james-83-renegade-section-section-build-1596929"]1983 cj7 renegade thread[/URL]
seabass1858 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 04:39 PM   #5
JayCJ5
1974 CJ5
I hadn't thought about re-sleeving. I can look in to that. I'll have to check the other adds. I think I would still need a new crank or some serious balancing on the one I have. Any recommendations on solid machine shops in the Denver area?
jay
Unread 01-06-2014, 05:15 PM   #6
seabass1858
1983 CJ7
did a little poking around for you when it comes to engines. http://theamcforum.com/forum/sleevin...opic24655.html
Unread 01-06-2014, 05:21 PM   #7
FLynes
FLynes's Avatar
1976 CJ5
So, what I gathered from that thread is that it can be done, but it needs to be done by a machinist who knows what he's doing. If you only have to sleeve one cylinder, then I'd say it's more cost-effective than buying a new block, if your sister is on a budget.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
Unread 01-06-2014, 05:30 PM   #8
Matt1981CJ7
1981 CJ7
Jay,
If I built another AMC engine, I'd use Spitfire Engine and Performance in Denver. They aren't the most professional shop you'll find, but they know AMC engines well, and have a proven record on local tracks.
Be advised, cash speaks loudly with these guys.
Good luck,
Matt
Unread 01-06-2014, 09:04 PM   #9
MoC
Hey Jay, welcome to the forums. We vacation from Louisiana to the western slope areas of Colorado every summer. Drove Mosquito Pass last year in July for the first time. --> Pictures Here <--
Great ride for sure! Good luck on you V8.
MoC is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 09:13 PM   #10
COBRA5LADDICT
Back when I built my first 304 you could pick up complete 360's from wagoneers all day long at pull and save off 33rd and Peoria. Back then a full engine complete was abou $150. Great core for a rebuild.
COBRA5LADDICT is offline   Reply With Quote Quick reply to this message
Unread 01-07-2014, 10:04 AM   #11
JayCJ5
1974 CJ5
Thanks all for the great advice. I had forgotten about Spitfire. I think those guys did the machine work on the 360 in my CJ-5 back in the day (late 90's)? I'll have to check with them.
jay
Unread 01-13-2014, 04:00 PM   #12
JayCJ5
1974 CJ5
Just a short update. Dropped off the block and crank at Spitfire on Friday. They think it can be re-sleeved (good news), but the crank is bent (bad news). So they are doing the machine work and getting the new crank. Should be done in a couple of weeks. Spent the weekend ordering additional parts so everything is ready to go back together. Can't wait!
Thanks all for the advice.
jay
Unread 01-13-2014, 06:02 PM   #13
Matt1981CJ7
1981 CJ7
Jay,
Good news. I hope the Spitfire boys treat you well.
Keep us updated.
Matt
Unread 01-13-2014, 06:37 PM   #14
swatson454
1983 CJ7
Jay, that appears to be the coveted "3/4 race" cam.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote Quick reply to this message
Unread 01-13-2014, 07:58 PM   #15
lucdog
lucdog's Avatar
1980 CJ5
Shawn
That's a good one Shawn, thanks buddy, ya made me smile. :-)
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
