My Nutter Experience. Praise Nutter (and Luckycheesehead)! - JeepForum.com
post #1 of 4 Old 04-18-2009, 02:31 PM Thread Starter
Sixcarbs
Hello fellow CJ'ers, just wanted to share my Nutter experience.
My 85 CJ-7 was having idle issues, missing issues, and loss of power issues. My mechanic (on this tiny island I live on) suggested a new carb, then I learned about the Nutter bypass.
I brought him the Luckycheesehead instructions from this site and he got it done. Woohoo!
The first 40 miles it felt like a new ride, I couldn't believe it. But then it started bogging down again under load. But the idle was still great. My uneducated guess was I really did need a new carb or the new vacuum advance was leaking.
Today I went to the store to buy some carb cleaner. I noticed and grabbed a bottle of STP carb cleaner and poured that in the fuel tank right away. That seemed to instantly help, or maybe it was just a coincidence.
Anyway, got home, took the air cleaner assembly off, gave it a good cleaning, taped up the "T" where the Nutter vacuum advance was spliced into the vacuum line, and shotgun sprayed a bunch of carb cleaner down the throat of the carb. (I don't profess to really know what I am doing.) I also put in a fresh air cleaner filter
The result.....AWESOME! It's better than when I left the shop yesterday. It hauls up hills without losing power or missing. The throttle response is instant.
I drive daily on dirt roads they could test lunar buggies on. I also have to drive up some curved, dirt hills to get home. I don't need to off road, my life is off road. I suspect I will have to learn to clean the carb on a regular basis.
Thank you Mr. Nutter, Luckycheesehead and the rest of Jeep Forum.
Sixcarbs is offline
post #2 of 4 Old 04-18-2009, 03:03 PM
Military Jeeper
1979 CJ5
I've heard of the Nutter Bypass before............send me the directions you mentioned when you get a chance.
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
post #3 of 4 Old 04-18-2009, 03:09 PM
Mike Romain
It is a way to make the computer controlled engines run like yours is already set up so it can't help you.
Here is the link anyway, it has vacuum setup info also:
http://www.jeepforum.com/forum/showt...ghlight=Nutter
Mike
Mike Romain is offline
post #4 of 4 Old 04-18-2009, 03:52 PM
Bubba Ray
I have done the bypass twice and both times it made a real difference in the way the CJ's ran. A real improvement.
Bubba Ray is offline
Anyone want to help me nutter? In N. Fla... jlr69s Jeep CJ Forum 9 04-29-2008 08:41 PM
Nutter mod Truck633 Jeep CJ Forum 6 03-14-2007 12:22 PM
nutter and HEI? jdb_us1 Jeep CJ Forum 3 07-16-2006 03:41 AM
The Nutter headgasket Jeep CJ Forum 0 03-06-2006 08:14 AM
to nutter or not to nutter? wm69 Jeep CJ Forum 3 07-20-2004 07:05 AM
