My New to me '84 CJ-7. First Jeep and first post too. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My New to me '84 CJ-7. First Jeep and first post too.
Engo winches available at www.rockridge4wd.com! Free shippJeep speedometer gears at rockridge4wdDana 30 Truss for your TJ, LJ, ZJ, and XJ
Unread 08-07-2011, 11:28 AM   #31
Gunsmith_207
1979 CJ7
Looks good!!!!
Gunsmith_207 is offline   Reply With Quote
Unread 12-27-2011, 06:08 PM   #32
diddy2003
Originally Posted by Gunsmith_207 View Post
Looks good!!!!
Thanks man
diddy2003 is offline   Reply With Quote
Unread 12-27-2011, 06:18 PM   #33
diddy2003
Here are some updated pictures. I had the inside lined with SEM Rock-it bedliner. http://www.tcpglobal.com/autobodydepot/sembedliner.aspx I also had the half doors, that used to be blue, painted black. The mirrors on them have been removed. I bought a set of axles, D30/AMC 20, with 4.10 gearing, but those haven't been installed yet. The front has a detroit trutrac and the rear has a trac-lok. Just waiting on the funds to buy a lift and tires right now.
Here is a little vid from a few days ago. I didn't get stuck, I just had to back up a bit and go around the rock. It was fun but the gearing was terrible in the woods. The open diffs and the 31 inch A/Ts didn't help much either, but it was still fun to play around in the woods regardless, haha.
http://s283.photobucket.com/albums/k...-34-45_648.mp4
Unread 12-27-2011, 07:46 PM   #34
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Looking good. Did he replace the vertical brace that runs from the windshield hinge to the floor when he put in the patch panels? That's what rusted it out in the first place was rust forming between the brace and the outer sheet metal.
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote
Unread 12-27-2011, 07:47 PM   #35
CrankyD
1983 CJ7
It will not be a hardcore off roading jeep. Probably a street jeep with the occasional woods day.
Yeah, thats what they all say...
Nice vid! I would freak out if I took new paint offroad, so mine is 5 or 6 colors right now.
CrankyD is offline   Reply With Quote
Unread 12-27-2011, 07:49 PM   #36
Jeeprage
Looks great. If you're ever in Braintree area, I'd love to take a look at a few things, as I'm going to putting a 92 tub on my 86 this summer.
Jeeprage is offline   Reply With Quote
Unread 12-27-2011, 08:08 PM   #37
Tylerzap
Im lovin' it
My 98 XJ "Zap" Build Thread
http://www.jeepforum.com/forum/f22/zap-98-xj-build-1462622/
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline   Reply With Quote
Unread 12-28-2011, 09:28 AM   #38
diddy2003
I don't think so. When he had it apart I didn't even notice if that brace was rusty. He didn't mention anything about it either.
I usually don't drive it very far and I rarely take it on the highway. The gearing is pretty ****ty right now, with the 2.73s. When I change them to 4.10s I hope that the drivability of the jeep improves. It has a hard time going up hills at speed now, which makes long distance highway driving miserable. If you are ever in this area hit me up. I can show you a place that can answer any question you have. They are called endangered species jeep and all they do is work on jeeps. They would be able to help you with anything you have questions on.
Thanks for all the positive feedback Its my first jeep and I love it. I guess I am a jeeper for life now
Unread 04-11-2012, 07:31 PM   #39
diddy2003
Ordered up a 4 inch lift, heavy duty shackles, stainless steel brake lines, and a steering stabilizer today. Should take 1.5 weeks to come in. I did get my tires in today. 33x12.5x15 MTRs. Also got the Jeep back from the paint shop today. There was a crack in the filler, where the steel was replaced, and my buddy wanted to fix it. The doors were also painted and fitted on to the Jeep. I wanted that done because I want to get a soft top and use the hard doors. Its running great but I have a small power steering fluid leak I will need to take care of at some point.
Sorry about the garbage iphone pics.
I will be putting on a set of axles (dana 30/amc 20) with 4.10s at the same time. The front has a Detroit truetrac and the rear has the trac lok. Should work well with the 33s.
Unread 04-11-2012, 07:54 PM   #40
JakeRod13
1978 CJ7
Great looking Jeep
JakeRod13 is offline   Reply With Quote
Unread 04-30-2012, 07:09 AM   #41
diddy2003
The lift just came in today. I am going to try and install it tomorrow. I did end up buying a soft top for it. I think it came out nice. Here are some pictures after I put a coat of wax on the Jeep yesterday.
Unread 05-07-2012, 08:23 PM   #42
diddy2003
After the lift and tires today. Getting it aligned tomorrow. It rides great and I really like how it turned out.
It now BARELY fits in the garage. I think it actually hit the arm of the garage door when I pushed it into the back garage. If it didn't it was a difference of a mm or something. Really tight. I how it sits down a bit when I break the springs in.
I just have to find a spare 33 inch tire now.
Unread 05-07-2012, 09:59 PM   #43
SuckerPunch
2014 JK Wrangler
Looks great! What kind of lift did you go with? And let me know how you like those tires. I'm thinking about going with those in 35's. Looks great with the lift. Did you do a body or shackle lift? Looks like it is sitting higher than just a 4" lift with 33's
SuckerPunch is offline   Reply With Quote
Unread 05-08-2012, 06:01 AM   #44
diddy2003
That is a Rough Country 4 inch lift. There isn't a BL on the jeep. The shackles are just Heavy Duty 3/8s Inch Shackles from Rough Country. They were the smallest I could get. I know what people say on here about RC, but the lift right out of the box rides better than the Jeep did before I put it on. I really like it, but I think I will like it more when I get it aligned and figure out whats going on with the castor geometry. So yes, it is just tires and a 4 inch lift basically. Also, consider getting your MTRs now with the goodyear rebate. I saved 160 bucks on mine with it.
Unread 05-08-2012, 06:19 AM   #45
BlindmeXJ
Looks amazing!!!
[COLOR="White"]1996 Cherokee Sport[/COLOR]
BlindmeXJ is offline   Reply With Quote
1984 , cj-7
