My New to me '84 CJ-7. First Jeep and first post too. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My New to me '84 CJ-7. First Jeep and first post too.
G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChBill Baird Motorsports DIY parts - NalinMFG.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-01-2011, 06:20 AM   #16
diddy2003
I think it came out pretty nice. Painting the wheels, aligning it, possibly installing rear jeep hi back seats, and putting the rear flares on today.
diddy2003 is offline   Reply With Quote
Unread 07-01-2011, 08:33 AM   #17
LT1CJ7
1983 CJ7
Looks way better than the rust bubbles, I hope you dealt with every rust issue.
Weren't the wheels chrome ?
Please tell me you putting the CJ rear flares back on, And getting rid of the hideous YJ flares.
Good Job, Keep up the good work!
LT1CJ7 is offline   Reply With Quote
Unread 07-03-2011, 03:01 PM   #18
diddy2003
I don't know about the wheels. They are poorly painted silver now, which will be fixed soon.
I kind of screwed up on the flares. I didn't think to check the mounting prior to paint. I should have filled the YJ flare mounting holes. I didn't. Looks like I have to fill and re-paint now or just run YJ flares. I am not happy about it. Sucks.
I did find baseball glove leather seats, front and rear, out of a Renegade. Those will look better than the garbage Nissan seats in there now.
Unread 07-04-2011, 08:26 AM   #19
Dave5liter
Look closely at the wheels. It mat not be silver paint. You'll know better than i because you have them there, but the original chrome wheels came with a factory clearcoat that tends to get hazy over time. If that's the case you can strip them and re-clear them in a weekend. My son and I bought a set and did this. I attached the before and after...Your jeep looks great btw. Good inspiration for me.
Dave5liter is offline   Reply With Quote
Unread 07-04-2011, 08:33 AM   #20
SKT
1981 CJ7
Originally Posted by Dave5liter
...the original chrome wheels came with a factory clearcoat that tends to get hazy over time.
Wow, those turned out looking great!
Not to hijack the OP's thread, but could you share the details on how you went about getting them to look so good?
Thanks
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is offline   Reply With Quote
Unread 07-04-2011, 08:48 AM   #21
Dave5liter
For obvious reasons, the wheels can't have any structural damage and hopefully minimal flaws in the steel (rust included). That will show through when you're done. I sprayed each wheel with Klean-Strip's Auto Strip Finish Remover. Let it bubble up the clear and gently scraped with a plastic putty knife. After the majority of the clear was removed, I went in with a water hose and rag to get the small bits. Dried the wheel completely and repeated a second time. After the old clear was gone and the wheel was prepped, I used Duplicolor's High Performance Wheel Coating Clear. The instructions call for two light coats followed by a medium coat. This produced a heavy orange peel look, so I went with a single medium to heavy coat and achieved a glass-like finish. Not certain how durable it will be as I've only got about 3 months on the wheels since I did them. Most people can't believe they are original wheels.
Unread 07-04-2011, 07:11 PM   #22
diddy2003
Woah, those wheels came out great!! Looks like I will have to look at them a little bit more closely. I just figured that they were worn silver.
Unread 07-06-2011, 02:36 PM   #23
diddy2003
So I took a look at the wheels. They appear to be black wheels that had been painted silver. The insides of the wheels are black and, when I removed the wheel weight, there was black under it. So it looks like I will just repaint them silver.
Also, my buddy is going to fill the YJ flare holes so I can put the CJ flares on. After the repaint of that area, we will wet sand the entire thing and smooth out the finish. It should look pretty good then.
Unread 07-06-2011, 03:56 PM   #24
LT1CJ7
1983 CJ7
The factory wheels never came black, So you might have another layer to get through.
Excellent
Unread 07-06-2011, 07:42 PM   #25
yleefox
I think it looks amazing already. Post some more photos when u get those flares installed and the paint polished. BTW, what's ur plans for wheels?
83 CJ7 AMC 304, Ford T-18 with Novak Adaptor, Dana 300 TC.
yleefox is offline   Reply With Quote
Unread 07-07-2011, 10:55 AM   #26
diddy2003
Thanks. That is what I figured but I wasn't sure.
I think I probably will just paint them silver. Not much different from the way they look now, just better looking.
Unread 08-01-2011, 12:27 PM   #27
diddy2003
Here is the Jeep as it sits today. It has been wet sanded, buffed, holes filled, fender flares installed, and the inside of the fender, that was still bare metal, has been painted.
Now it is at the shop getting new jeep seats, with Rugged Ridge covers, and a full tune up. I also am having them put on a bikini top. Nothing fancy, but I don't have a soft top so I want something there just in case it rains. It is coming along pretty well I think.
Unread 08-01-2011, 12:31 PM   #28
Transorange
1979 CJ7
Nice work! I like that clean and simple look!
[SIZE="2"][B]Jeep CJ7[/B][/SIZE]
[SIZE="1"]350sbc, SOA, Fiberglass body, 35s [/SIZE]
Transorange is offline   Reply With Quote
Unread 08-06-2011, 06:02 PM   #29
diddy2003
So here it is as of today. I found a set of seats out of a '80s renegade for 200 bucks. They are that baseball color. Then I put some rugged ridge neoprene covers on them. The seats I had before were out of a nissan and they were bolted in place. The new seats have all the correct hardware, which is awesome. I also had a minor timing issue and vacuum line issue, which is all fixed now. The best top bikini top was also put on yesterday. I think it came out pretty good. I think I am in to it for around 3 grand now. Pics to follow.
Unread 08-06-2011, 07:13 PM   #30
diddy2003
Here they are before a good wash. There is still a bit of wet sanding powder on it in the pictures.
1984 , cj-7
