My new CJ rebuild thread - Page 11 - JeepForum.com
post #151 of 153 Old 10-24-2011, 07:40 PM Thread Starter
Falcon_CMH
Now that the trollers are gone to get my thread back on track here goes.
The changes I have made so far:
New 94 amp Alternator (Bought original brackets on e-Bay)
Replaced PVC valve, air filter, oil, oil filter
Added used Half doors
Added new fan shroud (fixed temperature problem at idle)
Added new shifter handle
Replaced factory antenna with carbon fibre one.
Replaced the rear main bearing seal to stop oil leak (Also replaced oil pan gaskets, painted oil pan)
New changes in progress:
NP 435 tranny (tranny in hand)
Adding used full doors (doors in hand)
Adding hard top (hard top in hand)
Replacing valve cover seals, painting valve covers, new valve cover bolts
Other desired changes:
MSD ignition box, dizzy, coil
Pulstar plugs
Granetelli spark plug wires
Dana 44 front & rear (4.10 gears)
ARB Lockers
32" Tires
BSD 2 1/2" lift
Bilstein Shocks
TBI or EFI not sure yet
Power/Booster Brakes
210 York Air compressor
Lots of body work possibly new tub and panels
BigDaddy tie rod/drag link
Dual Optima Batteries
Warn winch
New drive shafts
AGR steering components (box, pump, rockram)
Bought a 1980 CJ-7 that I am rebuilding ground up:
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline
post #152 of 153 Old 10-24-2011, 07:47 PM
GlennLever
GlennLever's Avatar
Pulstar plugs
ARB Lockers
32" Tires
BSD 2 1/2" lift
Bilstein Shocks
Warn winch
New drive shafts
I purchased my steering gear box from crown, crown putts ARG's gear box, still sealed in ARG's box, into their box and ships it.
It is currently sitting on my front porch waiting pickup for a warrenty return.
See this link
http://www.jeepforum.com/forum/f8/st...stion-1279838/
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #153 of 153 Old 10-24-2011, 07:50 PM Thread Starter
Falcon_CMH
Yeah I saw that. Sorry for your problem. Hope I get a good one.
cj7 , rebuild
1983 Jeep CJ7 Rebuild Thread JKM3134 Jeep CJ Forum 65 11-20-2016 08:31 PM
AMC V-8 Oil Pump/Front Cover Rebuild Thread JeepHammer Jeep CJ Forum 26 02-13-2015 06:29 PM
Steve's 76 CJ7 Restoration - another rebuild thread sdrewel Jeep CJ Forum 3 03-18-2011 10:52 AM
My crunched CJ7, rebuild thread. crunched_CJ7 Jeep CJ Forum 3 02-16-2011 11:23 AM
Need help finding 258 rebuild thread.. Dave1980cj5 Jeep CJ Forum 1 12-18-2010 09:10 PM
