My name is Mud - JeepForum.com
post #1 of 33 Old 10-11-2013, 07:10 AM Thread Starter
Echo6CJ
1983 CJ7
My name is Mud
Whelp chalk one up for the new guy. So I am green to the whole mudding/wheeling thing. I have had my CJ for a year or so and all it has seen as of yesterday was school zones and traffic. So I slapped some mud tires on it and decided to get the old lady dirty.
It wasn't until I was knee deep in mud with my wife rolling her eyes beside me that I realized I needed to learn a thing or two about a thing or two.
So here was the setup and I will see if you can figure out what I had to learn later. I have an 83 CJ, inline 6, no lift, manual locking hubs, 31 inch mud terrains. I was out in the ranch a dried up muddy pond in front of me. I slapped that beast in 4H and went on my way. 3/4 of the way across and I was stuck. I lean my head out, back wheels are spinning, front wheels aren't doing a dang thing. My wife gazes out her side and mutters "I don't think you were going fast enough", meanwhile I start to think my Jeep is broken. I mean I thought this was a lightweight 4 wheel drive conquerer of the mud domain. Why wasn't my 4 wheel drive working?
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James "Mad Dog" Mattis
Echo6CJ is offline
post #2 of 33 Old 10-11-2013, 07:12 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
What transmission and, more importantly, transfer case are you running?
2Xtreme is offline
post #3 of 33 Old 10-11-2013, 07:13 AM
CrustySprings
Front lockouts (hubs) weren't engaged?
258 cu. inch six, Team Rush ignition upgrade, T5, Dana 300, Superwinch lockouts, Black Diamond 3" suspension lift, greasable shackles, poly bushings, JKS quick discos, 32x11.50x15 Cooper STT's, American Racing 23 15x8 alloys, Uniden Pro 520XL CB radio, 2' adjustable tip Firestick antenna, Viair 460 onboard air system
CrustySprings is offline
post #4 of 33 Old 10-11-2013, 07:14 AM
78FordF150
1983 CJ7
Did you unlock the hubs instead not knowing what you were doing?
Maybe the transfer case didn't lock all the way in and when you hit the mud it popped back into 2WD?
Sounds like the wife was a good sport though.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #5 of 33 Old 10-11-2013, 07:15 AM
scrapman
Did you have the hubs locked? You stated you "just slapped that beast in 4H". If you didn't get out and lock in the hubs, you were still just using the rear, and only one of those unless you have a locked rear end.
scrapman is offline
post #6 of 33 Old 10-11-2013, 07:22 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Kids these days.....
Matt
Matt1981CJ7 is offline
post #7 of 33 Old 10-11-2013, 07:23 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Question is:
Did she get out an push?
2Xtreme is offline
post #8 of 33 Old 10-11-2013, 07:24 AM Thread Starter
Echo6CJ
1983 CJ7
I didn't have the hubs locked.
Out of curiosity, after a little research, I read some stuff online but nobody was very clear or agreed on when you should lock your hubs. Do you always have them locked, only when you are mudding? What's the benefit of leaving them locked or driving in 2wd without them locked.
And to clarify for future purposes... Turn it clockwise to lock CCW to unlock? Is there a way to know they are engaged?
Echo6CJ is offline
post #9 of 33 Old 10-11-2013, 07:26 AM Thread Starter
Echo6CJ
1983 CJ7
Originally Posted by Matt1981CJ7
Kids these days..... Matt
What can I say... I blame the education system in America.
Echo6CJ is offline
post #10 of 33 Old 10-11-2013, 07:31 AM
Matt1981CJ7
1981 CJ7
If you need 4 wheel drive, lock the hubs, then shift the transfer case in either 4H or 4L. You know the hubs are engaged when the front wheels turn.
When you're done wheeling, unlock the hubs, and shift the t-case back into 2H.
Oh, and your headlight high-beam switch is a button on the floor that you press with your foot.
Matt
post #11 of 33 Old 10-11-2013, 07:31 AM
79jeepincj7
1979 CJ7
Clockwise to lock. And you only need to lock your hubs in when you want to use your 4wd. In the woods normally 4lo is the option you want. Mud as well and just grab a higher gear but 4 hi will suffice. Just lacking low end torque and can burn up your clutch depending on what you're doing.
When you unlock the hubs going down the road in 2wd the front axle shafts arent spinning so in turn neither is the ring and pinion or your driveshaft etc. Helps a little with millage (yeah right its a CJ) and just helps keep wear and tear off the front componenets.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #12 of 33 Old 10-11-2013, 07:36 AM
CJ7KAHUNA
I would say that if you intend to operate in 4wd you would need the hubs locked to achieve the desired effect.
EDIT:
JIC any of the "flame free" references alluded to this post let me be clear - I was simply stating that regardless of when you "should" shift into 4wd - the hubs will need to locked or your not going to engage your front axle. You just can't slap into 4H and take off.
To the OP - no flame intended.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #13 of 33 Old 10-11-2013, 07:37 AM
holliewood61
1981 CJ7
Ok here's the flame free answer. The stick in th floor engages the transfer case. The hubs engage the axle. If you only do one or the other you're not in 4wd. You don't generally want to have the hubs locked in on the black top (unless its snowing) it will cause binding. You want to lock your hubs in when off road before you get in trouble, not after.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #14 of 33 Old 10-11-2013, 07:53 AM Thread Starter
Echo6CJ
1983 CJ7
Thanks for the flame free answer. I acknowledge I am a novice and my mistake left me with egg(or mud) only face
Echo6CJ is offline
post #15 of 33 Old 10-11-2013, 07:56 AM
AcidLamp
Matt
So THAT'S what that does!
AcidLamp is offline
