My Jeep Resurrection Saga (finally) Continues..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My Jeep Resurrection Saga (finally) Continues.....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 04-30-2010, 07:07 PM   #1
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
So, after a bit over a year of very slow business coupled with a few health problems and surgeries, I'm back trying to do a little work on my Jeep resurrection.
Some might remember when I started back in 2007, I was trying to make Camp Jeep that year.
Yeah, that obviously didn't happen. The MAW's (Might As Well's) and WIT's (While I'm There's) killed me.
Well, that, and I got a boat that same year and pretty much went out every weekend.
Anyway, the boat is history, (as is most of my money) and I'm trying to do what I can with the Jeep....had shoulder surgery just before the first of the year and I still can't do much with it, but oh well....I am, anway.
So, my current task is fixing up this rear end. I have an 86 Dana 44, that had a disc conversion done when I got it. Trouble is, whoever did it might be the worst welder there is....but it did get run and they didn't break....Lord knows how, looking at the welds.
I've taken a few pics of the before, and how they looked after I ground the welds on the right side down:
Check this quality work out:
Are these not some sweet welds?
I'll continue this in the next post
Pacfanweb is offline   Reply With Quote
Unread 04-30-2010, 07:12 PM   #2
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
So out came the grinder:
You get the idea. I am a bit concerned about the apparent opening UNDER the bracket....will this give me a problem, or should I just weld the hell out of it correctly and it'll penetrate? Love to hear Besrk's opinion on this.
Unread 05-04-2010, 07:10 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Honestly, I'd grind until I could remove the brackets without bending them. Clean off all of that mess and weld them back on correctly. You got quite a bit of the old stuff off but there's still enough that I would be worried about new weld not getting good penetration.. basically just laying on that old stuff.
If this were something like a shock bracket, I might be tempted to risk it.. but with brakes.. better safe than sorry.
As for realigning the brackets.. should be able to install the calipers/pads and slide them in place on the disk to locate the bracket when you reinstall it.
I'll bet you could probably beat those brackets off with a hammer if you weren't trying to reuse them. That's how bad those old welds look..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 05-04-2010, 08:25 PM   #4
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Thanks a lot....I was afraid that's what you were going to say.
I wonder if I'd be better off just getting some new brackets....don't know how badly I'll mangle these getting them off.
Unread 05-04-2010, 08:48 PM   #5
JeepnBlake
I would just keep grinding off the boogers until they're gone and then weld them properly.
-Blake-
WTB: Currie Front Uppers CE-9102, Currie Double JJ Rear Trac Bar CE-9120R, & Currie Trac Bar Bracket CE-9121N, Or Currie Rear TB with Bracket Kit CE-9123N
Build Thread: http://www.jeepforum.com/forum/f22/j...thread-985907/
OEM Fog Light Connectors, Conversions, and Extension Info:http://www.jeepforum.com/forum/f20/o...ngler-1008928/
JeepnBlake is offline   Reply With Quote
Unread 05-04-2010, 09:30 PM   #6
alex211
Get some new brackets and do a nice job, whoever tried to put those on had no clue. lol
03 TJ
Build thread - http://www.jeepforum.com/forum/f9/my-rubicon-build-thread-slow-1255392/
alex211 is offline   Reply With Quote
Unread 05-05-2010, 08:39 PM   #7
OlivergreenCJ7
OlivergreenCJ7's Avatar
I really think it's all on how you look at it. The PO managed to weld on a bracket with little to no metal actually being connected... that has to be worth something.
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline   Reply With Quote
Unread 05-05-2010, 09:48 PM   #8
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
True....funny/scary thing is, he evidently ran it for awhile with no problems.
Also, before I starting grinding those magnificent welds off, I beat the hell out of the bracket with a good-sized hammer, and they didn't budge. Go figure.
