My float is stuck!! - JeepForum.com
post #1 of 8 Old 08-31-2012, 04:31 AM Thread Starter
somike
My float is stuck!!
After installing and testing (outside tank) my Equus fuel gauge and NEW sender, I reinstalled the tank and filled it with gas. The gauge now shows only 3/8 full with a full tank of fuel. The float inside of the tank must be stuck, since it worked OK outside the tank. Will some rough driving possibly work to get the float working again without dropping the tank again? I know just the trails that would make the fuel splash around in the tank quite a bit.
somike is offline
post #2 of 8 Old 08-31-2012, 05:52 AM
Mickey_Mouse
2013 KK Liberty
Mickey_Mouse is offline
post #3 of 8 Old 08-31-2012, 07:57 AM Thread Starter
somike
Originally Posted by Mickey_Mouse
some claim if you tap the gas tank with a hammer, it will loosen the sender, but then again, in the FSJ manual it says to check the tank for deformation. I measured my stock 15 gallon tank and had a reading of 10 inches from the lip. I was told a 6-12 inch adjustable GM sending unit would work. Another thing I would question is this, is the sending unit matched in ohms to the fuel gage. There are some gauge specific out in the aftermarket , match the gauge up to the sender either 240-33 to 240-33 or 0-90 0-90. Im thinking maybe the sending unit isnt matched to the gauge, or you need to adjust the sending unit again by a hair. I am planning on doing this as well, hope it works out great for you.
http://www.summitracing.com/parts/SW...61-F/?rtype=10
http://www.summitracing.com/parts/SWW-385CF/
Sender & gauge was tested before install and it worked OK. It just is sticking INSIDE the tank.
somike is offline
post #4 of 8 Old 09-01-2012, 12:03 AM
lucdog
lucdog's Avatar
1980 CJ5
My guess is the aftermarket float has a hole, or is just cheaply made . My new float/ sending unit lasted 2 weeks.
Bll
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 8 Old 09-01-2012, 03:06 AM
Mickey_Mouse
2013 KK Liberty
post #6 of 8 Old 09-01-2012, 03:59 AM
Hawk4097
I have had this issue before. You should just drop the tank. Make sure the float is in the right position. I had mine turned the wrong way so it was getting pinned because when it tried to rise up it was hitting the side of the tank. If the pickup and return line tubes are pointing to the drivers side it will hit the side and be inaccurate.
Hawk4097 is offline
post #7 of 8 Old 09-01-2012, 05:31 AM
gojeepin
1983 CJ7
Bll
Same here. My plastic float lasted about 2 weeks. As it slowly filled with gas it registered less and less. I had to buy a brass float.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #8 of 8 Old 09-01-2012, 07:33 AM
twoleos617
Cjponyparts.com has the floats for $6.16 shipped right now.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
Float bowl keeps draining out. em2mccue Jeep CJ Forum 12 06-08-2012 04:21 PM
Carb Float? pcg7384 Jeep CJ Forum 10 03-08-2010 07:45 AM
stupid float ! wetdog Jeep CJ Forum 3 06-12-2009 05:23 PM
Holley TA rear float OldSailor Jeep CJ Forum 0 06-03-2009 09:32 PM
Could this be the float adj. tarheel Jeep CJ Forum 5 11-10-2006 06:44 AM
