My Electric Fan Swap - Page 2 - JeepForum.com
post #16 of 115 Old 02-10-2011, 04:49 PM
rdsk8ter
1982 CJ7
your package is in the mail if you need any help wiring it let me know I have a whopping 30 bucks into my setup (relays,wiring two switches and two surface temp switches) and it works great
rdsk8ter is offline
post #17 of 115 Old 02-10-2011, 11:43 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Thanks so much, check is in the mail! When you get time throw up some pics of your fan wiring...
nedmoore is offline
post #18 of 115 Old 02-11-2011, 12:45 AM
rdsk8ter
1982 CJ7
theres not much to see other the wiring loom but ill draw up a diagram sometime soon too
rdsk8ter is offline
post #19 of 115 Old 02-11-2011, 09:55 AM
gijohn45
I would love to see that diagram as well... I am just about to do this swap myself...
gijohn45 is offline
post #20 of 115 Old 02-11-2011, 10:32 AM
Jim1611
Jim1611's Avatar
Ned I'll be watching this.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #21 of 115 Old 02-11-2011, 04:32 PM
rdsk8ter
1982 CJ7
dont know if this will help but
measurements
how I wired mine in
rdsk8ter is offline
post #22 of 115 Old 02-11-2011, 11:34 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
measurements
how I wired mine in
Thanks so much! Anyone care to chime in?
nedmoore is offline
post #23 of 115 Old 02-11-2011, 11:35 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Great! Now I am scared!!!
nedmoore is offline
post #24 of 115 Old 02-12-2011, 05:40 PM
Jim1611
Jim1611's Avatar
Hey I wanna learn something Ned, forge right ahead.
My build thread
Jim1611 is offline
post #25 of 115 Old 02-12-2011, 05:54 PM
Davidnex
1979 CJ5
nedmoore, looks like we're getting some good info here, I'm going to use contour's each fan on different t-stats
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #26 of 115 Old 02-12-2011, 11:45 PM
robert1973
1977 CJ7
I just a got countour fan set up free today, only problem is the wiring was cut off 3 inches coming out of it, what would be the simplest, easiest way to wire it, i would prefer to have it automatic but have a shutoff switch in case i ever did do a water crossing?
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #27 of 115 Old 02-12-2011, 11:53 PM
rdsk8ter
1982 CJ7
see above read the post above I think it was #21 its got a diagram its how i wired mine and they work great. low speed can be shut off high spped can be turned on, they both run low/ high off t-stats and high speed has an override to prevent accidental overheating
rdsk8ter is offline
post #28 of 115 Old 02-12-2011, 11:54 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Don't ask me! I am in Boston of all places! Give me a couple of weeks!
nedmoore is offline
post #29 of 115 Old 02-13-2011, 12:00 AM
robert1973
1977 CJ7
i came across this in my searching the forum, do you think this kit would work? http://www.summitracing.com/parts/FLX-31165/?rtype=10 I am not good at understanding those diagrams. What does the r1 and r2 stand for lol Relay?
ΜΟΛΩΝ ΛΑΒΕ
post #30 of 115 Old 02-13-2011, 12:45 AM
rdsk8ter
1982 CJ7
there are 3 relays you use 2 for the basic functions and the t-stat grounds the relay making contact then the em1 relay will kick high speed if I forget to flip the switch back on that kit might work if you dont know how to read the diagram above I would probaby shy away from doing that myself if I were you. Im by no means trying to put you down but If you but that kit it will have a wiring diagram that you have to follow just the same
rdsk8ter is offline
Electric fan GNARDOG Jeep CJ Forum 15 10-15-2010 04:54 PM
Electric carb cover; electric choke cover fell off ltbill Jeep CJ Forum 0 07-17-2010 05:00 PM
Electric fan swap RipLip Jeep CJ Forum 15 06-08-2009 08:36 PM
For those with a 4.0 head swap and electric fan setup... jennandal Jeep CJ Forum 0 03-07-2008 08:46 AM
Electric fan on 304 CJ7? CJBrando Jeep CJ Forum 2 08-22-2007 09:43 PM
