My Dash gauges don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My Dash gauges don't work
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-30-2013, 10:44 AM   #1
CJGUY81
1983 CJ7
Hi guys,
So I'm nearing the end of a CJ-7 project. My issue is that after replacing my wiring harness with a painless one my fuel, temp, oil, pressure and volt gauges don't work. Seems like this issue comes up a lot based on what I've read. I swapped out the oil pressure for a mechanical one so that is fine but the rest still don't work. I've read through some other threads and tried a few things without luck. Before i go and spend the money on a new instrument gauge I figured I would ask for help. Ideas? I don't have a multimeter fyi.
CJGUY81 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 01:20 PM   #2
pman
pman's Avatar
CJGUY81-
How do you get along without a multimeter? Or even a simple 12v circuit tester? Go get one!!! Why would you go buy a whole new instrument gauge without even confirming you have voltage to the leads?
Btw- even harbor freight has a free coupon for a multimeter.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 02:18 PM   #3
CJGUY81
1983 CJ7
Wow thanks for the help ..!..
With your input I will sleep better tonight. PFFT
Unread 06-30-2013, 04:21 PM   #4
thantos858
1974 CJ5
Hes pointing out the fact you need one to do most of the simple tests that you need to do.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 07:51 PM   #5
BagusJeep
1981 CJ7
He is right, you need some test gear.
A multimeter has its uses but a $5 12V test bulb with long leads is ideal for tracking down voltage on a CJ. You can hook on eend up to the battery negative and probe with the other end.
I would start at the fuse box. Test every input and output on each fuse. They sometimes blow but look OK.
Once you have voltage established you can go looking for voltage down the line to the gauges.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 08:15 PM   #6
HeathFinnie
1976 CJ5
Exactly. Without a mutlimeter or at least a test light, all we are doing is guessing as much as you are. Without some sort of test equipment we can't help you to know whether or not you would need to buy a new instrument gauge or not as we (and you) can't tell if it is a gauge issue or a wiring issue, or something else.
I'm currently trying to track down some electrical issues on my CJ5 and couldn't even start without at least a test light.
HeathFinnie is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 11:26 AM   #7
wm69
Get a multimeter. You'll be amazed at how often you use it, and how many things you can do with it.
Seriously.
wm69 is offline   Reply With Quote Quick reply to this message
