My CJ7 Tried to Kill Me! - JeepForum.com
post #1 of 28 Old 10-14-2009, 07:53 PM Thread Starter
putty31
So I am new to the Jeep world, and was driving home from work in my 86 CJ7 when I hit a pothole. It wasn't a very big pothole, but all of a sudden I jerked about four feet to the left into oncoming traffic. I was able to correct myself, and made it home (never going over 30 miles an hour). I parked her right in the garage until I can figure out what is wrong, so I figure I'll start here. I'm thinking either its the steering dampener or something is wrong with one of the shocks. The Jeep is sitting about an inch lower on the front left side, but I didn't notice that until it was parked in the garage. Any thoughts/help would be greatly appreciated. Thanks!!
putty31 is offline
post #2 of 28 Old 10-14-2009, 07:56 PM
WranglerZac
tire pressure is up to par?
Black Jeep Society #589
Michigan Jeepers #84
V5 Group #1
1994-YJ
2002-WJ
WranglerZac is offline
post #3 of 28 Old 10-14-2009, 07:57 PM
Cherokeester
Cherokeester's Avatar
1980 CJ7
Sounds like a bent tie rod or drag link. Also, check the spring on the low side for breaks or shackle misalignment. I broke the shackle mount on my cj7, it came right of the frame. That could be a possible cause. Make sure you inspect and fix the problem before you take it out on the road again!!
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #4 of 28 Old 10-14-2009, 08:25 PM
YOGI1
2014 JK Wrangler
I had a chevy do it once it was a ball joint on the dana 44. came with in a few feet of a head on. The guy I had just bought it from had put new ones on and didnt get a snap ring on right or put one on and didnt need it or something like that( getting old) any way check all your joints and bushing's. also be sure to check both axles and make sure the perches are sitting on the spring tie bolts right. that is a bolt that goes thru your spring packs that centers your axle. usally if they have moved there will be marks on the springs and the ubolts maybe loose, check your gearbox to and make sure it doesnt have to much play.
YOGI1 is offline
post #5 of 28 Old 10-14-2009, 09:09 PM Thread Starter
putty31
I too was thinking it could be ball joints...in fact I just got a set of MOOG ones that never need greasing. I suspected that too because sometime the steering would stick when I turned a hard corner (even at slow speeds). I was thinking that maybe the ball joints were rusted out so I was planning on replacing them this weekend...but was going to see if the weird "jerk of death" might have been something else. Thanks to everyone for their suggestions!!
putty31 is offline
post #6 of 28 Old 10-15-2009, 12:56 AM
gojeepin
1983 CJ7
I'm assuming you hit the pothole with your driver's side wheel. Has your axle shifted on the spring? If you sheared the centering pin your axle could slide back on the leaves.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #7 of 28 Old 10-15-2009, 02:54 PM Thread Starter
putty31
Thanks I'll check that....but the thing about the pothole is it was a very small one, like going over a manhole cover or something like that. That is what is so perplexing about this problem, though I am going to check it out this weekend when I have more than 5 minutes to do anything. Thanks everyone for your help!
putty31 is offline
post #8 of 28 Old 10-15-2009, 03:04 PM
Hybrid Jeep
1976 CJ5
Do you have a steering stabilizer installed? If not... installing one will limit violent motions like you experienced...
Hybrid Jeep is offline
post #9 of 28 Old 10-15-2009, 03:38 PM Thread Starter
putty31
Yeah I think there is one installed...it sort of looks like a shock and is right under the front of the jeep right?
putty31 is offline
post #10 of 28 Old 10-15-2009, 03:53 PM
jeeperman19
1984 CJ8
Yes the steering stabilizer looks like a small shock mounted horizontally under the front of your rig.
http://i95.photobucket.com/albums/l131/jeeperman19/carcrush-1.jpg
http://i95.photobucket.com/albums/l131/jeeperman19/rubiconmemorial.jpg
jeeperman19 is offline
post #11 of 28 Old 10-15-2009, 05:34 PM Thread Starter
putty31
Ok I'll probably replace that too along with the ball joints and see how that fares. Do you know if I would have to buy the whole kit or just the replacement stabalizer?
putty31 is offline
post #12 of 28 Old 10-15-2009, 06:10 PM
steveojeepster
1978 CJ7
might be a good idea to check the steering shaft. I had a bad coupler joint that caused my CJ to dance all over the road.
steveojeepster is offline
post #13 of 28 Old 10-15-2009, 09:54 PM
79cj7stone
1979 CJ7
oh i thought thats how all cj's drove!!! Guess not haha
79cj7stone is offline
post #14 of 28 Old 10-16-2009, 06:19 AM
KisDozerK3
OK nobody ask the right question.....HOW FAST WERE YOU GOING WHEN YOU HIT THE POTHOLE
KisDozerK3 is offline
post #15 of 28 Old 10-16-2009, 06:24 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Does the steering wheel sit in a new position now?
Did the steering wheel move when the jeep lurched?
Have a friend move your wheel as you look at the steering components.
John Strenk is offline
Fix it or kill it! fearsomfoe Jeep CJ Forum 1 05-22-2007 03:19 AM
Kill Switches 1979CJ7 Jeep CJ Forum 5 01-20-2007 12:42 PM
CJ7 tried to kill me n3480h Jeep CJ Forum 6 05-27-2006 10:05 AM
Kill Switch w/ HEI Ign Feenix Jeep CJ Forum 1 11-27-2005 11:22 AM
Keep it or Kill it crotz83 Jeep CJ Forum 5 11-25-2002 07:15 PM
