My CJ is running!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My CJ is running!!!
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 11-01-2014, 07:26 PM   #1
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
My CJ is running!!!
For the first time in over 2 years.. I started the CJ today! Very excited!
Believe it or not, I have not touched a single screw on the NOS Carter BBD. It's straight out of the box. This isn't one of the Chinese knockoffs.. It's the real deal made in USA. Haven't touched the timing either from where I set it after installing the reman distributor that has the better advance like the older 258's had. I guess I'm either really lucky, or maybe I do know what I'm doing around an engine once in a while
Here's video of it running! Gotta clean up the wire harnesses and finish installing interior pieces before I can drive it but very very close now!
http://www.youtube.com/watch?v=UJbpCUGg3to
'85 CJ-7 Laredo currently under construction.
My Rebuild/Restoration Thread, In Progress
BlkCJ7Laredo is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 08:08 PM   #2
jzjames
1980 CJ5
Yes! Hope you ARE lucky, the Carter BBD in my 80CJ5 runs very well. Keep it stock??
jzjames is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 08:27 PM   #3
dg6772
Congrats! I remember the excitement after mine sat for 15 years. Now get out and enjoy it!
Dave in Muskegon using Jf app
dg6772 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 10:24 PM   #4
RenoF250
Oooooohh that is clean and purty. Luck didn't make it run that nice, you had to do your part.
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 12:27 AM   #5
BlkCJ7Laredo
When completed will be all stock except 3" black diamond lift and 33" BFG mud terrains on black wheels.
