My CJ project - JeepForum.com
post #1 of 2 Old 05-23-2005, 09:20 PM Thread Starter
paraman72
My CJ project
Ok well I am not exactly new to this site for it is my second post....woohoo.
Alright on to business. I purchased a 79 CJ 5 for my project that has a good running 304 with tranny and transfer. But it has cancer really bad probably the ugliest to be seen, but hey it worked for my benefit. Since I have slightly longer legs I felt the CJ 7 would be a more comfortable ride so I found a reconditioned tub from a 84 CJ7 for dirt cheap. The only plans for the tube to make it original is to replace the floor pans ( appeared to have fiberglass repairs done ). I recently purchased an 86 CJ7 frame with the Dana 44 widetrack to be spine of this project. The frame has minor surface rust with the frame to body mounts needing replaced. I plan to use the front clip and motor and additional accessories from the 79. The trails are calling me but I am not sure I can make it to them until sometime next spring, so that gives me the winter to do the work. I have read some topics regarding liners to seal the frame and tub so it is been planned to go that route. I would like to hear from members who have done similar tasks for your comments and /or gripes. Thanks
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #2 of 2 Old 05-24-2005, 07:50 AM
dawgates
1980 CJ7
I would have said Powder Coat the frame when your finished , but I learned a costly lesson. Paint the from, if you plan to make any changes down the road and have to weld a bracket on the frame you'll have to grind the powder coating off, and then use paint to touch it up. I have to say it doesn't look pretty.
Sand blast the body's underside and use some POR15 to paint it. What the hell! use it on the frame too. You can touch it up if you change something. Hmmm, I'll have to write that down for myself.
Anyway now that I confused you and myself I'm going to work on my rig.
Keeps us informed as to your progress.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 12:38 PM
The New Project! PointBlank7 Jeep CJ Forum 85 08-03-2009 10:12 PM
My CJ7 project... fastang Jeep CJ Forum 8 03-05-2009 03:39 PM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 06:53 AM
Cj5 Project Jerry Reaves Jeep CJ Forum 3 09-30-2007 09:29 PM
