Are my brakes still good? - JeepForum.com
post #1 of 8 Old 10-18-2011, 08:39 AM Thread Starter
rjgruetter
I recently bought my first jeep, a CJ7. The brakes, however, are kind of slow to work. I'm wondering if it's because of the 35's and a v8, but i'm no sure. Anybody know the problem/solution?
WHAT? I'm sorry, I have no idea how your car got towed from the spot i'm in. WHAT? Um, no...the winch does not work...
rjgruetter is offline
post #2 of 8 Old 10-18-2011, 08:43 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
is it manual brakes? it shouldnt be as its an 85. but if they are that could be it, or your booster could be bad, or your MC, or your prop valve, or the pads, or the calipers. i run 35's with a yj booster/mc and stock cj brakes all around and mine will lock up the tires easy at any speed
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #3 of 8 Old 10-18-2011, 08:52 AM
ejeeperguy
1982 CJ7
I Would check to see if how the pistons work in the drums.They are cheap to replace if they are rusted or leaking.
The other thing to look into is upgrading to disc brakes for the rear.The kits are not cheap but with larger tires it would be one of those things that I would put in.The fronts have better calipers and discs too.Not as much as the rear conversion but will help stop alot easier.
ejeeperguy is offline
post #4 of 8 Old 10-18-2011, 08:54 AM
ejeeperguy
1982 CJ7
Oh I forgot the joke.
Stop I have a hard enough time getting it go and you want to stop.What's wrong with you?
post #5 of 8 Old 10-18-2011, 08:55 AM
RobsCrawlin7
no balls
theres also homemade kits you can put together rather than spend the pile of cash for the kits
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #6 of 8 Old 10-18-2011, 08:59 AM
ejeeperguy
1982 CJ7
Ryans
Where have you seen that I would like to know.I only run 33's but I always cross my fingers when breaking.Always wanted to upgrade the rear but $$$$$$ is the problem.
post #7 of 8 Old 10-18-2011, 09:45 AM Thread Starter
rjgruetter
Thanks for the info on the kits, i will check in on them.
post #8 of 8 Old 10-18-2011, 09:45 AM
RobsCrawlin7
no balls
im having a hard time finding it right now, but i remember it was nissan calipers and sammy rotors and a homemade bracket i think
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
brakes , cj7 , help needed
86 Dana44 brakes compatible with 82 amc20 brakes? 83vert Jeep CJ Forum 3 12-17-2010 12:44 PM
Another brake thread....YJ conversion, new master, good bleed, no brakes still Blthomas Jeep CJ Forum 38 05-18-2009 08:49 PM
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 11:06 PM
brakes not good garoughrider Jeep CJ Forum 1 02-12-2006 09:26 PM
Hydraulic brakes to power brakes question Jeep'N 4 Fun Jeep CJ Forum 5 03-05-2003 11:00 PM
