my bbc cj project - Page 7 - JeepForum.com
post #91 of 260 Old 09-04-2011, 09:50 PM
nshefbuch
1982 CJ7
Yea I don't understand how people say it weighs the same as metal. Me and my buddy had a hard time just us two moving a metal tub off and on however a fiberglass tub we could move with ease. Probably shaved off 200 lbs easily.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #92 of 260 Old 09-04-2011, 10:14 PM Thread Starter
kw89425
couldnt find much to get into. i got another small video ill get on later
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
post #93 of 260 Old 09-04-2011, 11:14 PM Thread Starter
kw89425
http://www.youtube.com/watch?NR=1&v=tTHA2xiOkHk
kw89425 is offline
post #94 of 260 Old 09-05-2011, 06:17 AM
AFRd_CJ5
1976 CJ5
Keep in mind that most fiberglass bodies aren't just fiberglass. Any of the "good" glass bodies have bonded plywood in key areas for strength/durability, so that's going to significantly add to the weight.
We weighed full on CJ's, but never just the body themselves, so I'm not 100% sure what the difference is. Our comparison was between about 3 fiberglass CJ's, and 1 steel CJ (all SBC/th350/d20 drivetrains), and all with basically the same axle packages.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #95 of 260 Old 09-05-2011, 06:42 AM
nshefbuch
1982 CJ7
I understand what you are saying but really? If the only thing different is the tub then the fiberglass one is lighter weight. The new ones use metal where the wood used to be.
post #96 of 260 Old 09-05-2011, 08:01 AM
AFRd_CJ5
1976 CJ5
Yes, really.
Read my post carefully. I am not saying 100% there is no weight difference whatsoever. I am merely listing what we experienced. Unless you have had both bodies sitting side by side and weighed them, can you say 100% for certain they don't weigh the same? I've seen people say 100lbs, and I've seen one person say 4WD told them they'd save 600lbs going to fiberglass. Is there a difference? Most likely, but is it that big of a difference? I don't know for sure.
'76 CJ5
AFRd_CJ5 is offline
post #97 of 260 Old 09-05-2011, 08:59 AM
nshefbuch
1982 CJ7
Yes, really.
I can 100% say they don't weigh the same. Read my post, we've lifted both metal and fiberglass several times and they do not weigh the same. Your jeeps must have had something else different for the weight to come out the same. Maybe you weigh 200 lbs and the other guy weighed 400 lbs while you guys weighed them but it has to be something else. I am not disputing this anymore as there are so many variables to why those jeeps weighed the same like IE: tires and rims making up the difference.
post #98 of 260 Old 09-05-2011, 09:06 AM
nshefbuch
1982 CJ7
Originally Posted by kw89425
That is some serious power you got there. You definitely need some mufflers though. Maybe some 70 or 80 series. 40 or 44's would be way to loud for that beast.
post #99 of 260 Old 09-05-2011, 09:45 AM Thread Starter
kw89425
i have a set of summit mufflers they look like a flowmaster just trying to gather the cash for the pipe work
kw89425 is offline
post #100 of 260 Old 09-10-2011, 01:28 PM Thread Starter
kw89425
with mufflers ill do this again outside i think it will sound better
kw89425 is offline
post #101 of 260 Old 09-10-2011, 09:02 PM
toyfarm
You got yourself a real chic magnet...cause if theres 2 things women love, its Jeeps and BBC!
'o5 Rubicon 4" RC X-lift and 33's <---- mine
'o5 Willys Edition w/4" lift and 33's <----hers
Connersville, Indiana
toyfarm is offline
post #102 of 260 Old 09-11-2011, 12:47 AM Thread Starter
kw89425
lol
kw89425 is offline
post #103 of 260 Old 09-11-2011, 06:24 PM Thread Starter
kw89425
this one sounds better
kw89425 is offline
post #104 of 260 Old 09-11-2011, 07:15 PM
toyfarm
Great lope! I could listen to that all day!
toyfarm is offline
post #105 of 260 Old 09-11-2011, 07:19 PM Thread Starter
kw89425
me too. thats the sound of a full roller motor
kw89425 is offline
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
New Project Help???? FavaGuitars Jeep CJ Forum 4 11-21-2008 10:39 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
CJ5 Project redcj576 Jeep CJ Forum 13 12-28-2007 06:40 AM
My CJ project paraman72 Jeep CJ Forum 1 05-24-2005 06:50 AM
