ok guys its been awhile. i havent had time to work on the cj but we have gotten started. turns out my frame wasnt in great shape so we mocked up the motor in the old frame and transfered it over to the good frame. i hope the pics work they arent the best. axels are in motor trans and case just need to fab the cross member the put it together or something like that..lol what do you guys think? oh yeah this is the 600hp stroker
Well took the bad boy deep in the woods and hills did great. About ten miles from the house the fuel pump died!!!! At least it didnt do it deep in the woods.
Tell me about it...That's what I've been doing too. My poor CJ thinks I forgot about it. I walk by it every day, once on my way out to my truck, once again on my way back in the door. Paychecks sure look nice, but I've got no time for anything else but sleep.
LOL Yeah, no kidding! Just browsed through the pages I missed since I last looked at this thread...wow, nice progress! I can't get the vid to play that you've got of it running, though...I'll have to try again later I guess.
I commented on the exhaust thread, but what cam is that? Sounds like a pretty chunky solid cam. I'd love to know the specs on the motor. I'll have to back up through your thread to see whats going on in there.
Its a 496 stroker 4340 crank and rods 10:25.1 j&e pistons big oval port heads worked with a 300 306 roller and roller rockers with a holly dominator intake and topped with a 950 hp
I did that on mine. It's worth the stretch, but unless you want to run degree shims, you have too be careful how long your shackles are, and build some height out of your spring hangers in the front. It will probably lift the front near a couple inches when you do the reversal. Good luck! :thumbsup:
Ok i have finally stated my rear bumper. I took enough pics you can see where im going with it and i am going to cut the corners and not leave it square or open. What do you think
Thats what the 1/2" plate is for i still have to make the holes then ill round the corners. I tried to email you back but its full and wont let me delete any off with the phone. We built my buddy the same motor with a 292 comp cam for his yj sounds and runs good
You mean the same engine as my 355, or the 355 you built? (vortec headed?)
I'm gonna take swatson454's advice and swap out my Melling cam, before I put it in anything else. Probably be a comp or lunatti. I want more low end off idle torque, not worry so much about the high rpm. In the Camaro we were in a foot brake class, leaving off a stock convertor. It still launched about 1800-1900. Don't need that in the CJ.
I need to take some pics of the bumper I'm gonna build. I had some tread plate bent for my rockers, but he bent the first set wrong. So he gave me all of them free of charge (the right ones and the wrong ones). I'm gonnna use a left over peice of 2x4 tubing and lay the treadplate on, like a step bumper. Box it in nice, put on the shackle mounts,to help get ya out of that lake
Lol.. Its a vortec headed 355. He hasnt had any problem with lowend running the 292. It ia a little bigger than most people would run in a jeep but he wanted it to hit so thats what i gave him. What do i know mine is a 300/306 roller.
I have several Holleys to choose from, 600, a couple 650's, a 750 double pump, 600 or 650? spread bore(forget on that one). a couple edelbrocks (but I hear they suck for off road). Even have a quadrajet (unsure what size that is).
that's what I been hearing, probably gonna leave two barrel on it for now. Maybe swap over this winter, I have the edelbrock intake already and an adapter for the q-jet.
If your good with Q-Jets maybe I could just pay you to rebuild it for me?
Once ya convert everything on a jeep to chevy ya got something worth writing home about ...... :laugh: (yup my opinion, and I sticking to it) :2thumbsup:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
