my bbc cj project - Page 17 - JeepForum.com
post #241 of 260 Old 09-13-2013, 06:55 AM
AFRd_CJ5
1976 CJ5
Originally Posted by Blown7 View Post
Well there is alot more to it than that...
First I want a looser Torque converter in the high 2.8K-3.2K stall range to get into the torque band at the stall off the line and allow for flash if necessary.
Better off the line launch..... Then there is highway speed where I regularly run 100+MPH in road race courses and want the low heat build up of a lock up converter.
As good as the TH400 is ... and I built mine with the best of the best...it can't do all that what A 4l80 will do without breaking a sweat
I have 3.73's and 35" Toyo's and I still want the engine running a lower RPM when my gas mileage is 6 miles to the gallon.
Right now I run out of redline RPM's and of axle gear at 135 MPH... I need OD
What drivetrain do you have making 900HP and running a converter with less than 2,800 flash?
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #242 of 260 Old 09-13-2013, 09:48 PM Thread Starter
kw89425
Still no answer. Research maybe?
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
post #243 of 260 Old 09-13-2013, 09:54 PM Thread Starter
kw89425
Wagon axles...lol
kw89425 is offline
post #244 of 260 Old 09-14-2013, 08:14 PM
papa355
1977 CJ7
Only time my jeep will ever see high speeds is when its on the trailer, lol. even then it will be going the speed limit, cus I'm tired of feeding the damn Bears
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #245 of 260 Old 09-14-2013, 08:26 PM Thread Starter
kw89425
My speedometer isn't hooked up so I never go over 55. The pete turns 1500 at 80
kw89425 is offline
post #246 of 260 Old 09-15-2013, 06:39 AM
Blown7
Not sure what your asking?
Converter less than 2800 flash?
My current converter I got shafted on.. had a trans shop charge me $3K years ago for a full upgrade and never got what I paid for, right now I have about 1800-2000 stall just about stock... when I asked for a 2600 stall.
Right now I'm converting another TH400 to a switch/pitch converter and then modify a 4L80 converter to be used to gain TCC lockup.
Transfer case is a 1339 QT modified with 300M internals.
Axles are 44 waggys converted to 2007 big 44 gears and full float 300M shafts and joints. More than equal to Dana 60 axle specs for input torque.
Blown7 is offline
post #247 of 260 Old 09-15-2013, 08:14 AM Thread Starter
kw89425
How are you getting 900hp
kw89425 is offline
post #248 of 260 Old 09-15-2013, 10:56 AM
papa355
1977 CJ7
that thing must have some long legs in her
papa355 is offline
post #249 of 260 Old 09-15-2013, 11:07 AM Thread Starter
kw89425
It'll go bout as fast as you need to
kw89425 is offline
post #250 of 260 Old 09-15-2013, 11:54 AM
Blown7
Lots of air
Blown7 is offline
post #251 of 260 Old 09-16-2013, 04:43 AM
AFRd_CJ5
1976 CJ5
Sounds nice! What do you use the Jeep for?
Just curious, but why did you ask for a 2,600RPM stall?
'76 CJ5
AFRd_CJ5 is offline
post #252 of 260 Old 09-16-2013, 05:27 AM Thread Starter
kw89425
I have a 2800-3200 i had in a car im going to use. Still trying to round up parts
kw89425 is offline
post #253 of 260 Old 09-16-2013, 06:35 AM
Blown7
Street, offroad, hill climb, mall driving.
The stall is way too low for a rip rocking dead start, good thing it has lots of low end grunt to get moving.
With both front and rear four link suspemsion it just squats and goes, it would be better to get in the torque band for even better acceleration.
However on the opposite side then highway mileage suffers, as I think I've said before when I can only get 6 1/2 miles to the gallon of gas so I'm trying for any kind of economy i can get.
Not so much for cost of the gas but even with a 25 gallon fuel tank filling up every 140 miles on a road trip gets old real quick.
Blown7 is offline
post #254 of 260 Old 09-16-2013, 06:49 AM Thread Starter
kw89425
Horsepower and fuel economy dont go together. Chances are that you lower rpm at hiway speed it's not going to get better.
kw89425 is offline
post #255 of 260 Old 09-16-2013, 06:50 AM
AFRd_CJ5
1976 CJ5
I wouldn't think that combo would be any good for offroad, or at least what I would guess you mean by offroad (trails/rocks/etc.). I guess I would have expected anybody with a engine setup like that, a custom converter would have been built to suit the rest of the combo to get the most out of it.
'76 CJ5
AFRd_CJ5 is offline
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
New Project Help???? FavaGuitars Jeep CJ Forum 4 11-21-2008 10:39 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
CJ5 Project redcj576 Jeep CJ Forum 13 12-28-2007 06:40 AM
My CJ project paraman72 Jeep CJ Forum 1 05-24-2005 06:50 AM
