My 86 cj7 will not shut off with key switch - Page 3 - JeepForum.com
post #31 of 39 Old 12-05-2012, 08:13 PM
86cj74.2L
86cj74.2L's Avatar
You pulled the two prong connector out of the back of the alternator and it stayed running, correct?
86cj74.2L is offline
post #32 of 39 Old 12-05-2012, 11:30 PM
BagusJeep
1981 CJ7
Originally Posted by DENVAR03 View Post
Hi
i rechecked wiring,and it looks ok.i tried pulling the 2 wire connector off alt.,when running,and it still runs!!!!.also i tried pulling the red/wht. Wire off solenoid,but engine still runs.had to pull dist wire to coil to shut down.what could be wrong?????>
One of the early questions was whether disconnecting the alternator changed anything. Apparently not.
So we have been through the possible causes:
1. Feedback from alternator. No, it makes no difference when disconnected.
2. incorrectly adjusted ignition switch. No, there is no power to the Red/white wires in STOP/OFF.
3. Faulty solenoid. No, it can be disconnected and makes no difference.
4. Wired coil to a Red wire (permanently on). No it turns on and off OK if it has not been running.
I am stumped. The only thing I can think is that this is an intermittenet feedback issue and the diode is still needed. It is a cheap and quick bit to install.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #33 of 39 Old 12-06-2012, 12:05 AM
86cj74.2L
86cj74.2L's Avatar
It be nice to have him probe the plus of the coil with the test light and shut off engine and tell what the bulb does while engine runs.
If it shuts off by its self after a few seconds,if I read the one reply correctly, I'd lean towards the switch adjustment. With the connector pulled from the alt I don't see how any feedback can still be happening it doesn't stop engine from running when it's pulled.
post #34 of 39 Old 12-06-2012, 01:37 PM Thread Starter
DENVAR03
Id another testing today!!!!!!!!!
Engine off: Key off
coil- nothing
sol.- nothing
engine off:key on
coil-dim
sol-dim
alt-red screw lug wire-hot
2 wire plug,both wires-hot
engine running:
Coil-bright
sol-bright
pulled 2wire plug out,and engine still runs,and rpm picked up a little,and both wires read hot!!.
The first time i shut it down,it stopped immediately,next time 2 sec.,next time 3-4 sec,last time,about 5 sec.
Dennis
DENVAR03 is offline
post #35 of 39 Old 12-06-2012, 03:53 PM
86cj74.2L
86cj74.2L's Avatar
When the engine stops a few seconds after you turn off ignition and your holding your keys in your hand.......to me anyway........is the switch adjustment.
The two prong connector is what you pull if engine stays running with your ignition keys in your hand to test if you need the diode.
post #36 of 39 Old 12-06-2012, 06:21 PM Thread Starter
DENVAR03
Guess i did it the wrong way!!!
I will test for diode again.i pulled plug,with engine running,and key in and on.i will shut,with key in hand,and test alt. Plug.
Thanks dennis
DENVAR03 is offline
post #37 of 39 Old 12-07-2012, 12:53 PM Thread Starter
DENVAR03
Cj74
think i am ready to throw the rope ,with the loop over the beam!!!!!!!!.went out to do the check,on alt.,and started it up 5 times,and it shut off immediately!!!!!!no time to run around other side to pull plug off alt.i will post again,if the delay starts up again!!.
Thanks for now
dennis
DENVAR03 is offline
post #38 of 39 Old 04-19-2013, 07:37 AM
Chlarock
Same problem
I had the same thing happen. all you guys are over thinking it. You have the constant power going to the wrong wire. It was a while ago but I think it was yellow. Look at the ingintio wires on the column and figure out were that power wire goes. Its just spliced to the wrong connection.
Chlarock is offline
post #39 of 39 Old 04-19-2013, 05:49 PM
86cj74.2L
86cj74.2L's Avatar
For me and Grammys CJ it was the starter solenoid start bypass contacts were bad.
