My 85 and 81 CJ7's builds - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My 85 and 81 CJ7's builds
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 09-01-2010, 04:09 PM   #1
Texas Jeep
Here is the 85 CJ7. the PO did some kind of bedliner inside with out sanding it very good. I removed the seats so I can clean it up and spray Als liner. It came with hard doors, they are just not installed. The V8 360 has some oil leaks that will need to be fixed. I already replaced the inner seals on the front axel that was leaking.
--Chris
My Build
2013 JKU Rubicon Crush
3.5 RK lift with 35 inch Duratrac's
Texas Jeep is offline   Reply With Quote Quick reply to this message
Unread 09-01-2010, 04:15 PM   #2
Texas Jeep
Here is the 81. It is my hunting jeep, but has alot of cancer. I'm installing hard doors and replacing the windshield and frame. I am also painting it with the roll on method.
--Chris
My Build
Unread 09-01-2010, 04:31 PM   #3
kakai81
Looks like you have your work cut out for you. Where are you in Texas?
kakai81 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2010, 05:27 PM   #4
Cherokeester
1980 CJ7
Gotta love the grenade shift knobs! You have your work cut out for you, good luck.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline   Reply With Quote Quick reply to this message
Unread 09-01-2010, 05:28 PM   #5
Texas Jeep
Yes I do. I hope I don't give up. I am south of Houston. In Matagorda county
--Chris
My Build
Unread 10-23-2010, 02:26 AM   #6
Texas Jeep
update. I sprayed in Al's liner in both jeeps. Looks good. I fiberglassed all the rust in the huting jeep and installed some new metal on the sides. Also I painted the hunting jeep green with the roll on method. The first 3 pictures are the 85 that is going to be a DD. the others are of the 81 hunting jeep( ie POS)
als-liner1.jpg   als-liner2.jpg   als-liner.jpg   huntingjeep-006.jpg   huntingjeep-007.jpg
--Chris
My Build
Unread 10-23-2010, 07:24 AM   #7
243
1978 FSJ Cherokee
Great start on both
My 83 is a retired Texas Deer Lease Jeep
What are your build plans for the 85?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2010, 01:32 PM   #8
Texas Jeep
My plan is to have the 85 as a daily driver
--Chris
My Build
Unread 10-23-2010, 03:07 PM   #9
243
1978 FSJ Cherokee
Are you planning on a lift, tires, new engine?
Unread 10-23-2010, 03:34 PM   #10
Texas Jeep
on the Green Hunting jeep (81 CJ7) no. it is a POS but runs good. The 85 is going to be a DD and it has a 4.5 inch lift and 33 inch tires. My wife is only 5' 2" so that is high enough for her.
--Chris
My Build
Unread 06-13-2011, 09:41 PM   #11
Texas Jeep
Update. I rebuilt the 360 and it runs great. Just bought all the stuff to Team Rush it. The stearing gear box was leaking so I am replacing it and it will be on the road.
--Chris
My Build
Unread 06-14-2011, 07:08 AM   #12
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Any new photos? We're all photo hounds...
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
