My 84 cj restoration - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > My 84 cj restoration
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 11-05-2009, 08:44 AM   #1
Bisqwik
I introduced myself a few weeks ago and posted the start of the project. I thought it would be better to do it this way.
I am restoring my Jeep I got new. I got a SBC years ago. It has been parked.
I cleaned it. Then stripped down to frame and body. I installed a 2" body lift.
As of last night I have the frame and body painted with POR 15. The engine bay primed and painted.
This weekend I hope to have the axels installed. I am installing a shackle reverse kit and a BDS 4" lift.
A photo of skinny me in 84 with my grandfather.
http://inlinethumb51.webshots.com/27...600x600Q85.jpg
Por 15 on frame and body
http://inlinethumb28.webshots.com/12...600x600Q85.jpg
the engine bay in primer
http://inlinethumb57.webshots.com/43...600x600Q85.jpg
Garnet 3c paint base and clear
http://inlinethumb14.webshots.com/43...600x600Q85.jpg
I will also update my progress on this thread.
My webshots links has more photos.
John
http://community.webshots.com/user/bisqwik
Bisqwik is offline   Reply With Quote
Unread 11-05-2009, 08:47 AM   #2
ElZorro
You posted the thumbnail versions of the pics. Pretty hard to make out any detail.
ElZorro is offline   Reply With Quote
Unread 11-05-2009, 09:07 AM   #3
Bisqwik
ElZorro Thanks
I fixed it I went back and changed. When my probation is over I will post the photos direct.
John
Unread 11-05-2009, 09:10 AM   #4
ElZorro
Click free.
John
Unread 12-03-2009, 08:25 AM   #5
Bisqwik
I have not posted in a while. I have still been working on my CJ. I have been a little side tracked by a old Border Patrol Rubicon TJ I got for my son. Kind of neat they put a 4” lift and 33” BFG M/T on it. The air lockers a sweet. The first thing at the house we had to take it in the back to find mud.
Back to my CJ, I have got the Dana 30 back in. I installed a lock-rite and new seals. Need to take some photos.
I got my NV 4500 home. I bought it from a friend. I had him install the Advance Adapter kit to mate it to a Dana 300. I came from a very low mile 2wd gas GM truck. I got the GM bell housing and slave/though out bearing. I will need to install a clutch master cylinder. I hope to dummy it up this weekend for fitment. I might need to go with the Dana 300 twin stick shifter. The Transfer case sits about 5.5” further back. The trans shifter is close to the same spot as my old t-176. I would still like to use my factory console.
I need to get back on my rear end. My new longer RE spring/axle pads came in. I will weld my tubes to the 3rd member. The set the rear end angle when I get the engine and transmission installed.
I love how at first I told the wife I was going to bring the jeep in and knock the old dirt off, re-ring the 350 and install new breaks and rear axles.
new BDS lift, Reverse shackles, paint, new Ground Ponder Fab built bumpers front and back. New steering gear box and shaft. Were do I stop???? Basically a rebuild from the ground up.
My Chevy 383 ci was going to be a carb engine. Now I am waiting on my fuel injection unit to come it. I ordered a First System. Here is a photo link.
http://www.firstfuelinjection.com/ed...20hood%202.jpg
I am planning to run 12 x 36 tires. I know my axles are next. I will get the jeep running and driving first. I am pretty sure I will go with 4.88’s. I have 4.10’s now. My new engine should have tons of low end power. It looks that I will go with a 9” rear. The front will be a 9” or a Dana 44. While we are on that subject are all Dana 44 ends the same size? Say a GM truck. Will the cast “C’s” on the end of the housing take the Dana 30 knuckles?
John
Unread 12-03-2009, 10:14 AM   #6
Bisqwik
My rear bumper just came in today with one for the TJ.
John
Unread 12-14-2009, 12:23 PM   #7
Bisqwik
This weekend I installed the JB Conversions HD output shaft, twin stick spring set and their LowMax 4 to 1 gear set in my Dana 300. I also got the NV 4500 dummied up with an old small block. Need to finish up the rear-end and get the transfer case install with the shifter then decide on final position.
It is all coming together slowly.
John
Unread 03-03-2010, 02:23 PM   #8
Bisqwik
It has still been going slow. We have been working on my sons TJ’s.
Got the engine built, installing the FI unit. I have the NV 4500 and the Dana 300 4 to 1 installed. I modified the stock skid pan and mount to work. I think it came out good. I did not give up any ground clearance. I also welded the AMC 20 tubes.
Next need to swap out the dummy engine and run the fuel lines.
I will try to get some photos.
John
Unread 05-24-2010, 02:20 PM   #9
hippiejesse
1973 CJ5
Gotta' love working on two Jeeps at once; I can relate, but in reverse... I work on my TJ, dad's CJ5, and dad's F-250, so none of them ever get attention for long periods...
Keep it up, looking good!
2000 TJ, (The daily)
1973 CJ5 (The love affair)
hippiejesse is offline   Reply With Quote
Unread 05-26-2010, 08:37 PM   #10
78orangejeeper
1978 CJ7
What color is it painted? I love the color and may be interested in painting mine that color.
78orangejeeper is offline   Reply With Quote
Unread 05-26-2010, 09:10 PM   #11
frank c
1981 CJ5
Nice job your'e doin keep up the good work.
Looks like an AMBER color from the pictures one of my favorite metallic shades
frank c is offline   Reply With Quote
Unread 05-26-2010, 09:32 PM   #12
carldimery
1979 CJ7
sorry to get off subject for a bit but........ where did you find a Border Patrol Jeep? i live in NM and would love to find out how to source one being that i live in a border state. Thanks.
carldimery is offline   Reply With Quote
Unread 05-27-2010, 09:51 AM   #13
Bisqwik
The Paint is color Garnet. It was used from 84 to 86. I got the Jeep new. I need to get back to work on it.
The first USBP Jeep came out great. Still have a little more work. Need to update the TJ post. They show up time to time at sales.
Ask a used car dealer in your area to check the auctions. My son is loving it.
Unread 10-24-2011, 08:23 AM   #14
Bisqwik
I have been away a long time. To many other projects. I have made up my mind. The AMC 20 and Dana 30 will go now not later. Now to decide Ford 9"s or Dana 60's.
Unread 10-27-2011, 07:39 AM   #15
Bisqwik
Here is how I modified my skid plate for the NV4500. I sectioned and welded a .25 plate in. I twin sticked the Transfer Case. I had to tweak the shifters so I could use my factory console. The NV4500 is longer than my old t-176.
Here is the 383 that is going in. Need to plumb the fuel rails and install the engine harness.
John
