My 83 CJ-7 build up - JeepForum.com
post #1 of 30 Old 06-01-2013, 04:58 PM Thread Starter
Cwill03a
1983 CJ7
My 83 CJ-7 build up
Ok, I'm going to attempt to finish this Jeep in a month and a half. As of right now, it is a rolling chassis. I am currently attempting to figure out how to route the fuel lines (there were none when I bought the chassis), as well as the brake lines. Everything I have done soo far has been a direct result of the information I have found on this website, so I decided I should give something back by posting my build up. Hopefully it will help someone with theirs, as well as giving me the opportunity to bounce questions off of you guys. I attempted to sell this Jeep as a Knee-jerk reaction to a military move, but I have decided to try to get it into one piece before I leave, so that I still have a Jeep. Here is my progress soo far (some of these images may look familiar if you follow the classified section).
Cwill03a is offline
post #2 of 30 Old 06-04-2013, 09:57 PM Thread Starter
Cwill03a
1983 CJ7
Came home today to brand new fuel lines and brake lines from 4wd.com. Unfortunately one of the fuel lines was kinked. This jeep started as just a frame (no brake lines or fuel lines). Does anyone have pictures (with labels) of the fuel lines? I know they should only go one way, but they all look the same to me.
Cwill03a is offline
post #3 of 30 Old 06-05-2013, 12:23 AM
dg6772
I think the fuel lines differ from side to side depending on engine. The six cylinder ran down the passenger side.the brake lines down the drivers side.
dg6772 is offline
post #4 of 30 Old 06-05-2013, 12:38 PM Thread Starter
Cwill03a
1983 CJ7
I THINK there the fuel vapor line runs down the passenger side, and the tank to pump line, return line, and brake line run up the drivers side...I think. Mine is a V-8.
Cwill03a is offline
post #5 of 30 Old 06-05-2013, 01:49 PM
hasselback
I just got a roll of aluminum tubing for my fuel lines. Ran the send and return both on the drivers side.
hasselback is offline
post #6 of 30 Old 06-05-2013, 02:28 PM
dg6772
That's the beauty of what you have........unless it's a restoration; do what works for you! That's what I did.
Good luck!
Dave in Muskegon
dg6772 is offline
post #7 of 30 Old 06-05-2013, 03:23 PM Thread Starter
Cwill03a
1983 CJ7
I got all of the brake lines and the new proportioning valve put in today. Picked up a nice looking transmission and transfer case today for $250. Also, dropped the 304 block to a new (new to me) engine shop this morning. He was not impressed with the machine work of the "racing engine" machine shop. I wish I would've known about the new shop in the first place. Hopefully this guy won't let me down.
Cwill03a is offline
post #8 of 30 Old 06-05-2013, 03:28 PM Thread Starter
Cwill03a
1983 CJ7
Not sure why I can't post multiple pictures per post
Cwill03a is offline
post #9 of 30 Old 06-05-2013, 03:29 PM Thread Starter
Cwill03a
1983 CJ7
The trans and t case
Cwill03a is offline
post #10 of 30 Old 06-29-2013, 11:58 AM Thread Starter
Cwill03a
1983 CJ7
I started building the 304 today, however, the rear main bearing doesn't fit. To be more specific, it won't fit the crank. There is also a gap at the back of the bearing. The Clevite part number checks out correctly, but it's not right. Has anyone else run into this problem?
Cwill03a is offline
post #11 of 30 Old 07-19-2013, 08:06 AM Thread Starter
Cwill03a
1983 CJ7
My newly rebuilt 304 is in, now it's on to the T150
Cwill03a is offline
post #12 of 30 Old 07-19-2013, 08:08 AM Thread Starter
Cwill03a
1983 CJ7
Having a little trouble getting the T150 to go the last 1/2 inch. I'm not a transmission expert (just getting it over the frame rails and onto the cross member sucked), so that probably didn't help.
Cwill03a is offline
post #13 of 30 Old 07-20-2013, 05:24 PM Thread Starter
Cwill03a
1983 CJ7
Finally got the trans installed! The crossmember had to be re-drilled. I'm pretty sure I have a crossmember for a newer T4/T5 trans. The tail shaft isn't perfectly lined up, but I think this will buy me the time to find a new crossmember or a 4 speed trans.
Now it's time to get the driveshafts extended. I found a guy in Nashville that will do both driveshafts for $100. That sounds like a pretty good price to me. So, I'll drop them off on Monday, and pick them up in the afternoon. I'm a little surprised that I only need about an inch on each shaft. I figured that a 7" lift would need more.
While I'm in here today...has anyone ever tried to put a T150 or T15 into a 80-86 CJ-7? Mine is an 81-ish, but I spent 3 days trying to get everything lined up. I'm curious if maybe it was just the crossmember that caused my problems. I have the 80-86 crossmember, but I think the 76-79 may have bolted right up. Unfortunately, I don't have the older version.
Cwill03a is offline
post #14 of 30 Old 07-21-2013, 12:00 AM
Renegade82
1982 CJ7
Great posting. But I'm thinking it would be easier if you weren't building it upside down. (and quicker)
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #15 of 30 Old 07-22-2013, 09:29 PM Thread Starter
Cwill03a
1983 CJ7
Wait...what?!! What's upside down?
Cwill03a is offline
