My 76 CJ7 Project - Page 4 - JeepForum.com
post #46 of 101 Old 04-15-2011, 09:23 PM
parrotparty
How's the SOA set up holdin up?
Originally Posted by 243 View Post
....I don't know that my way is the right way, it is just the way I did it.
Originally Posted by freedommachine View Post
If it makes you paranoid and requires forum discussions it belongs on a Jeep.
"Well boss, a diesel needs its oil like a sailor needs his rum."- Capt. Ron
parrotparty is offline
post #47 of 101 Old 04-16-2011, 09:19 AM Thread Starter
KMD
1976 CJ7
No problems so far. really like it. It rides better than the 99 TJ.
Any questions hit me up. Been working on some rust and getting ready to monsterline the inside.
KMD is offline
post #48 of 101 Old 04-16-2011, 09:30 AM Thread Starter
KMD
1976 CJ7
Some prep work for The Chassis saver and monsterliner.
Lots of holes to fill in.
KMD is offline
post #49 of 101 Old 04-16-2011, 10:37 AM
Jim1611
Jim1611's Avatar
Ought to look great when you get the liner in.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #50 of 101 Old 04-16-2011, 06:08 PM Thread Starter
KMD
1976 CJ7
Some pictures of filling in the quadratrac shifter hole on the driver side, and making the hole around the transfer case shifter smaller with proper clearance to shift smoothly. P/O installed a dana 20 with a J shift pattern.
After fill in.
Shifter filled in.
Door supports welded to stiffen tub.
Drivers door with added material to door striker area.
First coat of Chassis Saver drying.
KMD is offline
post #51 of 101 Old 04-16-2011, 08:50 PM
243
1978 FSJ Cherokee
Looking great! Why did you choose Monstaliner over U-pol?
Dave's 78 Build
243 is offline
post #52 of 101 Old 04-17-2011, 08:16 PM Thread Starter
KMD
1976 CJ7
Jeep Forum supporter, I think it is a better product after some research, I can talk directly to the owner almost any time on here or pirate. That means a lot when someone is that intouch with their customers.
KMD is offline
post #53 of 101 Old 04-18-2011, 05:40 PM Thread Starter
KMD
1976 CJ7
Time for the Monstaliner.
Front section cut in with the paint brush.
First coat in waiting to setup for second coat.
Did first coat with the small roller in the first picture.
KMD is offline
post #54 of 101 Old 06-22-2011, 04:03 PM
Jeepican
1976 CJ5
Hey ... did you ever get an aftershot of your completed Monstaliner job?
Thanks!
Jarod
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #55 of 101 Old 06-22-2011, 08:27 PM Thread Starter
KMD
1976 CJ7
I am not sure. If not I will post one up this weekend.
KMD is offline
post #56 of 101 Old 06-23-2011, 12:38 AM
Capt_Drake
Originally Posted by r08ert209cali View Post
Some pics of the drive train insulation I installed to keep the heat and noise from inside my tub.
undercoated and painted
the insulation
Installed
What type of insulation is this and where'd you get it??? and how's it holding up??
How much of Chassis Saver did you use?
Thanks, looks GREAT by the way
Capt_Drake is offline
post #57 of 101 Old 06-24-2011, 06:13 AM Thread Starter
KMD
1976 CJ7
chassis saver used less than a quart for two coats.
Insulation from Pep Boys lasted about a month. need something heavier like aluminum. would only work good under carpet on the interior. I knew that going into it but had to try. I think it is called jute padding.
KMD is offline
post #58 of 101 Old 09-09-2011, 01:05 PM Thread Starter
KMD
1976 CJ7
Had body work started this week almost done. hope to paint next week.
There was some rust in this area, had it repaired.
KMD is offline
post #59 of 101 Old 09-09-2011, 01:35 PM
Jeepican
1976 CJ5
What color you going with?
-Barney Fife-
Jeepican is offline
post #60 of 101 Old 09-09-2011, 02:06 PM
SKT
1981 CJ7
Originally Posted by jeepican View Post
what color you going with?
x2...
SKT is online now
360 , amc , cj7 , jeep , tube
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 12:38 PM
The New Project! PointBlank7 Jeep CJ Forum 85 08-03-2009 10:12 PM
My CJ7 project... fastang Jeep CJ Forum 8 03-05-2009 03:39 PM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 06:53 AM
Cj5 Project Jerry Reaves Jeep CJ Forum 3 09-30-2007 09:29 PM
