My 1979 CJ5 rides like a buckboard! - JeepForum.com
post #1 of 8 Old 12-03-2013, 09:00 AM Thread Starter
bobby4361y
IT has 4 wheel leaf springs. Is that the problem? Can new shocks help, at all? Am I facing a coil spring switch out? This is a weekend play toy, not a money pit! Or is it?
bobby4361y is offline
post #2 of 8 Old 12-03-2013, 09:09 AM
waterdowg
All CJ's have 4 leaf spings that is normal. Shocks will most likely not help. The spings are what gives it the ride. Do you have lift? That will also cause it. You can install YJ Leaf springs to soften the ride but that will onlu do so much. If your looking for a soft ride. A CJ is not for you. You may wan to sell it and look for TJ or JK. To swich over a CJ to coil will not be cost effective.
waterdowg is offline
post #3 of 8 Old 12-03-2013, 12:17 PM
Balvar24
1979 CJ7
Strange. I've always thought my buckboard rode like my CJ7?
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #4 of 8 Old 12-03-2013, 12:22 PM
222Doc
222Doc's Avatar
going coil over is a HUGE upgrade and is going to cost $$$$ thousands. that's if you can do the fab. if you have a pro do it well............add another$ sign.
though the ones in our clubs are awesome off road. but if cost means anything to you. much less to get better seats, suspension seats help alot.
222Doc is offline
post #5 of 8 Old 12-03-2013, 02:00 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
From what I have picked up on this forum:
Lift springs - the more lift, the harsher the ride.
Spring quality - cheaper is not better riding. Old Man Emu or Rubicon Express are the better ones from what I have gathered.
OEM style oil filled shocks only, no gas charged shocks. The oil-filled just dampen the springs. The gas charged expand themselves when unloaded, so now you have to compress the spring AND the shock...
Tire pressures overinflated - just because the sidewall says 50PSI doesn't mean that is what you run them at. That is the pressure for the max load the tires are rated for. Search on here for tire pressure recommendations to figure out what is best for you.
Also check spring bushings, as if the shackles were overtightened then the bushings cannot flex as designed.
Hope this helps...
Oh, an afterthought - CJ5 means you have a short wheelbase. This amplifies the roughness. The longer the wheelbase, the smoother the ride.
Rick
Cutlass327 is offline
post #6 of 8 Old 12-03-2013, 02:32 PM
ScroungerLee
I have seen comments where people got better seats and noticed improved comfort as regards rough riding. I am really not sure if you want the vehicle more stable or more comfortable, which is your priority?
ScroungerLee is offline
post #7 of 8 Old 12-05-2013, 12:02 PM
gmakra
Remove your springs one at a time and pull the pack apart. Wire brush between the leafs and put Never Seize inbetween the springs reassemble the spring pack, then call me in the morning with the results. You should see a smoother ride.
gmakra is offline
post #8 of 8 Old 12-05-2013, 02:04 PM
tdcanada
1973 CJ5
With adding the anti-seize theory, wouldn't adding greasable shackles help also?
Cant believer he insulted a buck-board like that
tdcanada is offline
