mvigo's '85 CJ7 resto/build saga - Page 18 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > mvigo's '85 CJ7 resto/build saga
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 07-06-2013, 08:09 PM   #256
Jim1611
Jim1611's Avatar
Originally Posted by SonicR1 View Post
I'm telling you Jim, we gotta meet up in Moab some time!!!
That's very possible someday!
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 09:04 PM   #257
lucdog
lucdog's Avatar
1980 CJ5
I would love to go on this trip!!!!!
Bill and Mike, if possible I'd like to see a comparsion between the Rubicon trail, and Moab. The Rubico trail is a loooooong way from central Il.
Have either of you guys done both?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 07-06-2013, 09:14 PM   #258
mvigo
mvigo's Avatar
I have just wheeled in CA, Fordyce, Rubicon being the toughest that I have had experience with. I would be up for a trip to Moab when time permits...which probably means kids need to be a touch older...but, you never know, and, I have time on my side because if we were to meet you and Jim at Moab, Jim needs to finish his Jeep first!! Easter Safari has always been in the back of my mind...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 07-06-2013, 09:27 PM   #259
SonicR1
Of course Bill, you are definitely invited!!! I told Scott a long time ago we all needed to go to Moab! I think he was the only nay sayer... I don't know if we will ever get him out of Florida!!!
I gave a dana 35 to a guy last week, he has been to both, he told me Moab is adult Disneyland! Trails ranging from mild to holy crap! He rented a JKR for his mom, it seems she used to race jeeps back in the day, and he said she had a blast on the mild trails.
I still haven't done the entire rubicon trail, and would love to do that some time!!! But I enjoy the trip that Mike puts together through the Tahoe side of the trail!!!!
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 05:41 PM   #260
mvigo
mvigo's Avatar
Finally had a chance to take apart the remnants of the busted lockout on the driver's side.
here are the pieces as they came off:
and here are the inners still on the stub axle:
interestingly enough, the cast aluminum outer housing is what failed. The inner parts all seem to be OK. My question to you all is this:
Can I just rebuild the lockout if I found a used outer housing with the remaining parts I have?
or should I buy a new set of lockouts, either Warns or Mile Markers, rebuild this one and use it and the passenger side as spares?
I was seriously considering upgrading to the 6 bolt hub/lockout but I am now convinced I like this set up better as this is a much easier trail fix when this fuse (lockout) blows then a u-joint, axle, pinion gears etc...
Chime in gurus, chime in...
Unread 07-07-2013, 07:50 PM   #261
SonicR1
I'd get a new set and have the passenger for a spare...
Unread 07-07-2013, 08:25 PM   #262
Skerr
Oh how I would love to go. Wifey says "yes"! But when? I have champagne taste but a beer budget! Lots to do before I can get to Moab.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 09:06 PM   #263
MoC
Wow Mike, it really did blow..
I'll get the outer hub mailed out to you Tues at the latest!
Thanks for the honey!
MoC is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 09:28 PM   #264
lucdog
lucdog's Avatar
1980 CJ5
This^^^
The first time I went to Moab I used a Dana 30 with 6 bolt lockouts. Warn axle shafts with 4.27 gears and 36" IROCS, a lockrite, and a beafed up factory driveshaft.
The easiest part to replace, should be the weak point. That part is the lockout.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 07-08-2013, 05:23 AM   #265
Skerr
Use a housing and rebuild it. You have the technology. You can make it better!
Kerrdog
Go Fish! <*////><
Unread 07-08-2013, 10:47 AM   #266
Renegade82
Renegade82's Avatar
1982 CJ7
Isn't moab out in a desert setting with mostly some rocks to climb around on; whereas the rubicon is more of a mountainous trail ride with a mixture of obstacles. Am I wrong on that?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2013, 03:31 PM   #267
mvigo
mvigo's Avatar
The Rubicon trail consists of some forest service roads with the tough parts traversing granite, huge boulders, rock gardens etc in a beautiful setting. You can camp in the Rubicon springs and swim in crystal clear water pooled up in granite bowls. I have not completed the entire trail but look forward to the day when I do. I take my kids down each summer with a few other families for a very long picnic/Jeep ride. we typically take 3 hours or so to traverse just 2-3 miles. and, if it rains, it can take longer. I have only seen pictures and video of Moab and one day I will get there...
Unread 07-08-2013, 03:32 PM   #268
mvigo
mvigo's Avatar
Your honey is in the mail, thanks again!
Unread 07-20-2013, 05:29 PM   #269
mvigo
mvigo's Avatar
on a side note, I have 5 original chrome wagon wheels available...PM if you care. Not sure how to price them...
EDIT: after further inspection these wheels are NOT OEM, they are aftermarket...thanks MoC for the heads up on what to look for...
Unread 07-20-2013, 08:21 PM   #270
MoC
Sure they are oem? Hard to tell from the picture but they look to be a little wider with an offset. Are the edges of the cut outs flat or beveled?
