mvigo's '85 CJ7 resto/build saga - Page 6 - JeepForum.com
 13Likes
post #76 of 402 Old 05-08-2012, 06:44 PM Thread Starter
mvigo
mvigo's Avatar
Originally Posted by lucdog View Post
No first hand knowledge on the internals of batteries. I do have 2 yellow top Optimas. I don't feel there holding a charge like they should.
I read that thread when it was active. My next batteries will be the type JH suggested in that thread.
My diesel truck uses interstate batteries, I got 6 years out of the original Motorcraft ones.
Bill
Bill,
and I got 6 years out of the 2 in my Jeep now which are 4 Wheel Parts brand gel battery...either way, I am saving the $$ and going with Hammertime as he has yet to let me down with any of his suggestions...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #77 of 402 Old 05-23-2012, 11:26 AM
SonicR1
Well, What's going on here? I have been stuck at work... new position... lots of overtime, so I haven't been able to do much with my Jeep, so you need to start working on yours!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #78 of 402 Old 05-27-2012, 12:56 AM Thread Starter
mvigo
mvigo's Avatar
A couple of quick updates...
1. fixed the brake light switch by adjusting it out a little more, thanks for that suggestion guys...
2. the original power steering pump just didn't have enough in it to power both the steering box and the hydroboost so I spent some time today installing my new AGR pump (Vanco recommended), very easy and straightforward...just have to finish bleeding the air out of the system...
3. as for batteries, I went with 2 Sears Platinum (made by Odyssey) batteries to replace the 2-6 year old batteries of which one died completely and the other went into my work truck. These batteries have a full replacement warranty for 4 years and then is prorated after that.
4. I still need to adjust my brake pedal a little more, still a tad too high for my liking but sonofagun do I have brakes now...
once I complete the power steering I plan on tackling the oxidized hood...
mvigo is offline
post #79 of 402 Old 05-27-2012, 06:11 PM
Skerr
Your brake improvement is one of those that always makes me want to spend money on my Jeep! You look at some improvements/mods and say, "That's nice", but the Vanco brake system is one of those that makes me WANT to buy it. Probably never will unless I win the lottery though!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #80 of 402 Old 05-28-2012, 09:38 AM Thread Starter
mvigo
mvigo's Avatar
Question for you gurus out there...
When bleeding the power steering system, I had my daughter turn the steering lock to lock for what seemed like 100 times. No more air bubbles, no foaming fluid but my power steering is not working correctly...seems at idle it is hard to turn the steering wheel. I believe the belt tension is good and I have no visible leaks. Any thoughts out there? Thanks in advance...
mvigo is offline
post #81 of 402 Old 05-28-2012, 11:09 AM
SonicR1
Maybe the pulley isn't right for your setup?
SonicR1 is offline
post #82 of 402 Old 05-28-2012, 09:37 PM Thread Starter
mvigo
mvigo's Avatar
same pulley Bill, the AGR pump is plug and play...I will call them manana...
mvigo is offline
post #83 of 402 Old 05-29-2012, 11:31 AM Thread Starter
mvigo
mvigo's Avatar
the Good news: I am not as dumb as I thought I was. I bled the system correctly, followed directions carefully and have a nice, leak free, air bubble free power steering system and hydro boost braking system. So I got that going for me...
the Bad news: AGR sent me out the wrong pump!! But, they are correcting their mistake and sending me out the right pump for my application at no additional cost (it is a few more $$) today. So, in a week or so I get to do the same job all over again...
mvigo is offline
post #84 of 402 Old 05-29-2012, 02:58 PM
Skerr
I think your bad news is actually good news! At least you know there is nothing else creating an issue. As you said, plug-n-play. Makes sense now that you know you have the wrong pump. Congrats on getting that one solved so quickly. Problems with new parts is one of those things we tend to overlook or disbelieve, and start taking apart something else.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #85 of 402 Old 05-29-2012, 03:47 PM Thread Starter
mvigo
mvigo's Avatar
Scott,
You are so right. I think I am fairly logical, can follow directions and can be very methodical when I take things apart and put them back together. But, when I venture into the unknown, the lack of experience causes me to 2nd guess myself when an install doesn't go exactly as planned like this one did. I don't have a ton of experience like many here on the Forum so I get really nervous really fast when something is not right. The thought of the wrong pump installed never crossed my mind.
AGR couldn't have been more willing to make it right and I really appreciate that. At least now I know how to install the power steering pump and the job should be cut in half, time wise.
Mike
mvigo is offline
post #86 of 402 Old 05-29-2012, 05:45 PM
Skerr
Mike
Kudos to AGR. Good customer support and a good plug for the company.
Your comment about knowing what to do now is the blessing of your effort. We sweat stuff out of ignorance because we have no confidence in ourselves. Then, we undertake the challenge, whip it, and think "That was easy". I think that's awesome. The Force is with you, Mike!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #87 of 402 Old 06-13-2012, 08:47 PM Thread Starter
mvigo
mvigo's Avatar
Well, if someone can figure out how to make time, they would be the wealthiest person in all of eternity!
AGR shipped out my higher flow power steering pump and I finally started to install it last night and finsihed up this morning. Flushed the power steering system real good, replaced the pump, bled the whole system again, checked for leaks, test drove, checked for leaks and am now back in action! The steering is effortless and the brakes stop on a dime and give back change. If you don't have a seat belt on, I can easily eject you like James Bond. It feels so good to drive the CJ again with doors & top off, nice California summer day/evening...can't beat it. Next project to tackle will be re-shooting my faded/oxidized hood. I am now off to install a beehive to another satisfied customer...Stay tuned...
mvigo is offline
post #88 of 402 Old 06-13-2012, 09:17 PM
Skerr
Way to go Mike! That's good news. You certainly are a busy-bee!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #89 of 402 Old 06-14-2012, 06:05 AM
Louie4
That's great! I'm looking forward to the hood restore.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #90 of 402 Old 06-17-2012, 09:38 PM
SonicR1
Shoot, no top off driving over here right now!!! 108 degrees is a bit much for no a/c!!!
SonicR1 is offline
Resto Q's neatocj Jeep CJ Forum 1 03-30-2011 11:12 AM
Resto: My current `83 CJ-7 or buy/resto a `70 CJ5? ShaggieSAM Jeep CJ Forum 33 11-13-2010 08:04 PM
saga continues cj7texas Jeep CJ Forum 2 06-13-2010 08:06 AM
my first resto.....ever daltonw Jeep CJ Forum 9 09-26-2009 07:22 AM
Help with CJ7 Resto 2000XPSD Jeep CJ Forum 9 08-24-2005 05:53 AM
