mvigo's '85 CJ7 resto/build saga - Page 14 - JeepForum.com
 13Likes
post #196 of 408 Old 02-02-2013, 03:03 PM
SonicR1
Mike, does that meen you have a tie rod reamer???
Oh, and where is the fuel pump now??? You have electric one with the FI, right?
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #197 of 408 Old 02-02-2013, 07:41 PM Thread Starter
mvigo
mvigo's Avatar
yup, and yours for the taking whenever you need it...fuel filter was old...fuel pump OK, yes, electric, mounted outside tank up above rear axle...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #198 of 408 Old 02-04-2013, 08:37 PM
SonicR1
Cool, I've been looking into steering mods, so that might come in handy... Although I don't have a lot of time to wheel my jeep let alone modify it...
SonicR1 is offline
post #199 of 408 Old 02-04-2013, 09:14 PM
lucdog
lucdog's Avatar
1980 CJ5
One of our older club mbers has one, single axle rear though.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #200 of 408 Old 02-05-2013, 12:43 AM Thread Starter
mvigo
mvigo's Avatar
Originally Posted by lucdog View Post
Attachment 557959
Bill
Do you know what year it is?
mvigo is offline
post #201 of 408 Old 02-05-2013, 06:43 AM
lucdog
lucdog's Avatar
1980 CJ5
Sorry, don't have a clue. The one our club member has is a 1972, looks like it just came from Vietnam. I'll post the picture over on Flynes thread.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #202 of 408 Old 02-05-2013, 07:59 AM
lucdog
lucdog's Avatar
1980 CJ5
I had a feeling Fred might know, or at least where to look. He hooked me up with this link.
http://www.jeepforum.com/forum/f8/6x...-mutt-1270259/
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #203 of 408 Old 02-05-2013, 03:48 PM Thread Starter
mvigo
mvigo's Avatar
Bill
Thanks Fred, via Bill...next time I am up there I will ask more about it...
mvigo is offline
post #204 of 408 Old 02-20-2013, 06:46 PM Thread Starter
mvigo
mvigo's Avatar
My Warn Rockcrawler tire carrier was beginning to wobble/rattle and I first thought that the female sleeve that slides over the spindle was wallowing out causing the rattle. I called up Warn to see what they said and they sent me some new nylon bushings thinking that my original one had worn down. It had, not sure if you can tell in this pic:
I greased up the spindle, greased up the new bushing and, lo & behold, a much tighter fit that eliminates the wobble...
Before:
and after all torqued down and greased up:
I never would have thought it would be that simple...
mvigo is offline
post #205 of 408 Old 02-24-2013, 08:09 PM Thread Starter
mvigo
mvigo's Avatar
A few weeks back the door paddle lever inside the driver's door gave way to the point where I could no longer open the door without reaching in through the window and opening the door from the inside. I finally got tired of that today and tore apart my driver side door to fix it as well as a few other items using Jeff Scherb's fantastic write up:
http://www.jeepforum.com/forum/f8/ga...2/index67.html
The "lever" in the red oval is what is bent out of shape from 28 years of non-stop use:
So, using Jeff's instructions to take apart a door, I finally was able to remove the paddle assembly from the door and bend down the "lever":
While I have the door apart I am going to weld up the infamous crack just below my window vent, strengthen up that area per Jscherb's thread, weld up the window hoop as it comes down to the door panel, and replace all the worn out window trim with new. I will do the same thing on the passenger side once the driver's side is completed to my satisfaction.
One question I do have is what is all the gunk at the bottom of my window?
I was driving South on Main street when a gal decided to turn left right in front of me without yielding (I was traveling around 35mph and I had the green light). Both air bags went off (1st for me) and the right front end of my pickup seems to be toast. Question for all of you gurus out there, will they total this Ford Ranger with 74k miles on it that was in great shape? or fix it? and, yes, I am OK as well as the other driver...
Lastly, Jeff Scherb, wherever you are? I owe you your favorite beverage, your write up(s) are priceless. so thank you!
mvigo is offline
post #206 of 408 Old 02-24-2013, 09:24 PM
firewalker909
O.k., one more.
firewalker909's Avatar
1973 CJ5
Wow, that sucks. Glad you weren't injured. Sorry, can't answer your question about whether or not they will total your truck.
firewalker909 is offline
post #207 of 408 Old 02-25-2013, 08:39 AM
Jim1611
Jim1611's Avatar
Great work on the door Mike. Glad to see that you or the other driver weren't hurt. I bet they total your Ranger, but maybe not. Hard to say. Both air bags going off is really going to jack the repair bill up.
Jim1611 is offline
post #208 of 408 Old 02-25-2013, 06:53 PM
ASteve
1972 CJ5
Mike,
Glad you and the other driver are ok!
How was the show? Any photos?
Good work on the door too, although I have no idea what a door looks like for a CJ except here on JF...Grin...
SC
ASteve is offline
post #209 of 408 Old 02-25-2013, 08:08 PM
SonicR1
At least you weren't driving th CJ!!! Glad you are alright!
Nice door fix!
SonicR1 is offline
post #210 of 408 Old 02-27-2013, 01:58 PM
Skerr
Glad you're alright Mike. I had the same thing happen to me, except I was in my '66 F100 4X4, and I totaled HER car! Good steel back then!
Thanks for dropping Jeff Scherb's link for the door repair. I had forgotten all about it! I'm going to need it. Besides bending down the tab, what else did you do? Seems like that little piece of metal will be weakened and will distort rather quickly??
Kerrdog
Go Fish! <*////><
Skerr is offline
Resto Q's neatocj Jeep CJ Forum 1 03-30-2011 11:12 AM
Resto: My current `83 CJ-7 or buy/resto a `70 CJ5? ShaggieSAM Jeep CJ Forum 33 11-13-2010 08:04 PM
saga continues cj7texas Jeep CJ Forum 2 06-13-2010 08:06 AM
my first resto.....ever daltonw Jeep CJ Forum 9 09-26-2009 07:22 AM
Help with CJ7 Resto 2000XPSD Jeep CJ Forum 9 08-24-2005 05:53 AM
