mvigo's '85 CJ7 resto/build saga - Page 13 - JeepForum.com
 13Likes
post #181 of 396 Old 01-14-2013, 07:01 PM Thread Starter
mvigo
mvigo's Avatar
My new HD tie rod and drag link came in from OK4WD. I bought the flip kit and will just flip up the drag link which I can tackle later this week as I only had time for the tie rod this afternoon. As you can see in the photo below, my original tie rod is bent out of line to the tune of 1/2" at the very end:
I removed the old tie rod and took a comparison photo of old vs. new:
The new tie rod is beefier and heavier and the install is just a couple of castle nuts torqued down to 50 ft lbs per factory manual...couldn't be easier. I went this route because I have no room to flip both the tie rod and drag link. Since I am leaving the tie rod in the original position at least it can withstand rocks better then the weaker OEM unit. I will be flipping the HD drag link later this week to return the geometry closer to it's original specs prior to my suspension lift. Last photo of it installed:
I was checking my bee hives at one of my bee yards and I came across this:
Vietnam era CJ6? I always come across something new at this particular yard.
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #182 of 396 Old 01-14-2013, 07:42 PM
SonicR1
I am impressed with the jeep, but you didn't get picks of the tank in the background!?!?!?
Oh, and beefy tie rod!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #183 of 396 Old 01-14-2013, 09:38 PM Thread Starter
mvigo
mvigo's Avatar
Stay tuned!
mvigo is offline
post #184 of 396 Old 01-15-2013, 09:54 AM
acgcoug
1979 CJ5
Mvigo,
What part of Northern California are you located?
I am in central coast Cali, Santa Maria/Orcutt.
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #185 of 396 Old 01-15-2013, 10:09 AM Thread Starter
mvigo
mvigo's Avatar
Originally Posted by acgcoug View Post
Mvigo,
SF Bay Area...I went to Cal Poly and love your neck of the woods...
mvigo is offline
post #186 of 396 Old 01-24-2013, 05:52 PM
Louie4
That's neat. I know Cal Poly is one the top engineering schools out west. Are you an engineer mvigo?
That new tie rod is pretty beefy by the way.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #187 of 396 Old 01-24-2013, 06:31 PM Thread Starter
mvigo
mvigo's Avatar
Nope, far from it, I was an Ag major and am now a beekeeper...
http://www.thebeeranchers.com/
mvigo is offline
post #188 of 396 Old 01-24-2013, 06:46 PM
WNC-84CJ7
Mike,
Your website is awesome, and I am kinda jealous of your job! I dig it- keep it up!
Chris
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #189 of 396 Old 01-24-2013, 06:56 PM
Louie4
That's neat. My wife's boss' husband (haha) does beekeeping as a hobby and we got some awesome honey.
Interestingly enough, my undergrad was in Ag. Engineering.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #190 of 396 Old 01-27-2013, 09:47 PM Thread Starter
mvigo
mvigo's Avatar
I spent the morning and early afternoon helping my pal swap in his new OME 2.5" suspension kit. We will finish it up once his new Crabtree shackles and hangers arrive. We took a break from his CJ to spend some time on mine flipping/installing the new HD drag link I ordered awhile back. Very straigtforward install and I had to grind the bushing down a smidge as it was keeping the TRE from seating in the new tapered hole that I reamed on the knuckle. As I mentioned earlier, there is no room whatsover for me to swap both the drag link and the tie rod without moving my steering box forward an 1" or so. The geometry is right back to factory settings and I will get an alignment done early this week.
mvigo is offline
post #191 of 396 Old 01-28-2013, 05:23 AM
Louie4
Nice!
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #192 of 396 Old 01-28-2013, 10:53 AM Thread Starter
mvigo
mvigo's Avatar
Originally Posted by WNC-84CJ7 View Post
Mike,
Chris
Thanks Chris, we try hard to keep it interesting...
The best part of the hive, IMO, is the wax cappings you get when you extract honey. I will put a big plug of them in my mouth and chew them like tobacco sucking the honey out of the wax...
I was an Ag Business Mgmt...
Nice!
thanks...
woke up to a Jeep that won't start...ruh-roh! It just sputters and dies. Let's hope the easy fix is replacing the fuel filter since it is due for one...
mvigo is offline
post #193 of 396 Old 01-28-2013, 03:42 PM Thread Starter
mvigo
mvigo's Avatar
sometimes you get lucky! I replaced the fuel filter and the CJ started right up. It turns out I had a cracked line from the tank going INTO the filter and I would bet that I was sucking dust, dirt and who knows what into filter? I cut into the filter just to see and, as the picture shows, there was caked on gunk at the end of the filter, unless that black "gunk" is supposed to be the latest and greatest filtering media from WIX (they manufacture Napa Gold filters)! Please chime away if you think different.
Also, the cracked line was 5/16" and the filter calls for 3/8" line going into it from tank and 5/16" coming out going towards fuel pump. I swapped in some high pressure 3/8" line I had in my pile of parts. I couldn't find a reason not to so if you know better, please holler...
EDIT: I am now thinking the "gunk" in the picture is some kind of adhesive (RTV type) to hold the filter cartridge to the cannister. No?
mvigo is offline
post #194 of 396 Old 01-30-2013, 11:13 AM
Skerr
I'm going to guess that is sediment over the years settling into the bottom of the filter. From the tank??
TR and DL look great, Mike. BTW, I was an Ag major too!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #195 of 396 Old 01-30-2013, 01:03 PM
lucdog
lucdog's Avatar
1980 CJ5
That's where they glue it to the outside canister.
Looks good, nice driveway surface too.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
Resto Q's neatocj Jeep CJ Forum 1 03-30-2011 11:12 AM
Resto: My current `83 CJ-7 or buy/resto a `70 CJ5? ShaggieSAM Jeep CJ Forum 33 11-13-2010 08:04 PM
saga continues cj7texas Jeep CJ Forum 2 06-13-2010 08:06 AM
my first resto.....ever daltonw Jeep CJ Forum 9 09-26-2009 07:22 AM
Help with CJ7 Resto 2000XPSD Jeep CJ Forum 9 08-24-2005 05:53 AM
