#1 | |
mud in brake drum??
did a little wheeling yesterday in some mud and water... now when i brake i hear some grinding/dragging noises from the rear. could i have gotten mud inside the drum? will it just work itself out? that was one of my first off road adventures, so i don't know if this is just a common thing or what... thanks!
[color=blue][b]1985 CJ7[/color][/b] MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20 |
#2 |
ok im an expert at this. this happens to me daily.
on the back of the drum is a little black plug, its for the adjustment for the shoes. this is there so when you first do your brakes you stick a flat hea dint here and turn a little spurred knob that adjusts the shoes out so they are stiffer. now when this plug is missing or rotted out its a gapping whole for everything and its mother to get int he drums. id check that to see if its there. second, drums will always get some sort of stuff in there because its not a sealed deal. there is a little slight gap between the drum and the backign to the drum that the shoes and all attach to. a little sand and such will get int here. if you here grinding just take it to the power washer and spray the hell outta the drums so the water flushes everyhting out. trust me this works
john 79 cj7 70 amx 360 turbo 350 12 inch lift 39.5's np 208 re quick disconnects rancho shocks cutom driveshafts snorkel 14 bolt rear international dana 70 front w/closed knuckles " damn modification bug bit me hard, so im bittin back!!" "Go mud or go home" |
#3 | |
#4 |
pine lands are my back yard.im in forked river right off the parkway. all i have to do is cross the parkway and im there.
where in jersey are you. yea jersey is sand and clay, i prefer the clay ![]()
#5 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
