MSD6a - will it fit behind cj7 glovebox? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MSD6a - will it fit behind cj7 glovebox?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteinjager TJ tube doorsAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONS
Unread 04-16-2014, 02:32 PM   #1
Daves86cj
Did the nutter, cleaned up the wiring, now I've removed the factory ignition module and trial installed a MSD6A and a Blaster 2 (used, from CL). The MSD stuff worrks great and now I want to do a permanent installation. I was going to mount it on top of the passenger fender like many have but with the old confuser gone I thought that maybe the msd6a would fit behind the glovebox and I could run the wires out thru that nice big grommet for a clean installation.
I've never had the glovebox out and I'm kinda lazy. Does anyone know if the msd box will fit behind the glovebox where the old computer was. When I took the old one out I was able to pull it out under the dash so I never saw where it was mounted.
Daves86cj is offline   Reply With Quote
Unread 04-16-2014, 03:16 PM   #2
Mike86CJ7
I mounted mine under the dash on the firewall and truly learned where the term "buzz box" came from. The emi noise emanating from the box is heard in my CB and stereo. Were I to do it again, I'd mount the MSD box out on the fender. Just food for thought!
1986 CJ-7: Fiberglass tub, 5" total lift, 33x12.5 M/T's, 258, Weber, T5, Dana 300, Dana 44 rear
Mike86CJ7 is offline   Reply With Quote
Unread 04-16-2014, 05:00 PM   #3
Daves86cj
Hmm, very good point on the emi Mike. I will definitely test it out first under the dash to see if I get any interference. As an amateur radio operator I've had a little experience with emi and sometimes it can be eliminated pretty easy with a filter or just good grounding. Other times it can be a real b*tch. But you are right that it's not worth a lot of effort if locating on the fender fixes it. Thanks for the advice!
Unread 04-16-2014, 05:06 PM   #4
garusher
1979 CJ5
I put mine on the firewall behind the air cleaner, do not know it this will be good or bad.
garusher is offline   Reply With Quote
Unread 04-16-2014, 05:38 PM   #5
Rusty4x
1981 CJ8
Area behind glove box
Here's a link to what it looks like behind the dash. Hope it helps.
https://www.dropbox.com/s/vi17pxokwhwu0yk/CIMG1953.JPG
Rusty4x is offline   Reply With Quote
Unread 04-16-2014, 05:46 PM   #6
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The ICM should be mounted where it can get a lot of air and stay cool. I wouldn't stick it behind the glovebox.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 04-16-2014, 07:49 PM   #7
BagusJeep
BagusJeep's Avatar
1981 CJ7
Bagusjeep Duraspark module sits behind the glove box on the firewall, plenty of space back there and it does not get very wet very often. Bagusjeep is open and unheated so as good as placing it under the hood, which gets rather hot. It depends on what else you have back there.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
BagusJeep is offline   Reply With Quote
Unread 04-17-2014, 05:16 AM   #8
AFRd_CJ5
1976 CJ5
I don't have a heater in my Jeep, but there's where my MSD box has been for many years without issue.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline   Reply With Quote
Unread 04-17-2014, 07:32 AM   #9
Thbugman
1978 CJ7
So I have a Mallory HEI in my sbc. Does a MSD6 really help that much?
Thbugman is offline   Reply With Quote
Unread 04-19-2014, 10:54 PM   #10
chris989604
1980 CJ7
i went next to the booster
chris989604 is offline   Reply With Quote
Unread 04-20-2014, 10:11 AM   #11
keith460
Jeep. There's Only One
keith460's Avatar
The MSD units are a little thicker then the factory MCU's but will probably fit in that space were the OEM computer was. They need to keep cool though.
I choose the upper portion of the passenger inner fender well to mount mine and after driving the Jeep around with 8 different locations of temperature probes, it confirmed it was one of the coolest area's for I6 equipped engine compartments. I used our test instruments from work called a 'MOLE' unit for balancing heat in large production Tunnel Ovens we sell. The probes were mounted around various sections in a Jeep CJ engine compartment.
Best locations with low heat: upper side of passenger fender, lower portion of driver fender(factory), under battery tray, topside of driver fender(near horn).
Worst locations with high heat: center of firewall above engine, anywhere within two feet of the exhaust manifold especially at idle.
The other areas of the firewall away from center were OK but still much warmer then the fenders.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 04-20-2014, 01:38 PM   #12
cjjon7
1983 CJ7
I modified the stock brains bracket and put mine in there, atop the heater box behind the glovebox...and yes it fits nicely with just slight modification to the oem bracket...fits nice and snug
cjjon7 is offline   Reply With Quote
Unread 04-21-2014, 07:01 AM   #13
GPER
1979 CJ7
I mounted mine on the back side of the dash where the speaker slots are.
GPER is offline   Reply With Quote
Unread Yesterday, 11:41 AM   #14
Daves86cj
Wow! Lots of good ideas. Thanks guys, I'll let you know what I end up with. I like behind the glove box for a clean install but the top of the pass. fender is better for serviceability.
Unread Yesterday, 12:27 PM   #15
AFRd_CJ5
1976 CJ5
I can verify it's a PITA to work on behind the glovebox
'76 CJ5
