Msd wiring help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Msd wiring help
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 05-16-2014, 09:22 PM   #1
pecos
Msd wiring help
Installed msd 6a. And crt performance juice box. Engine fires up fine but getting run on. I connected lg red wire directly to batt. And for the small red switched wire i used the harness supplied by summit with diode already attached. Im stumped, where could ignition be getting power.
pecos is offline   Reply With Quote Quick reply to this message
Unread 05-16-2014, 09:33 PM   #2
WindKnot
WindKnot's Avatar
1977 CJ7
The diode should be in the circuit from the alternator to the warning lamp in the dash. My year it's the small brown wire attached to the Delco 10SI alternator at terminal 1. If the diode is inserted backwards, it's the same as not being there.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is online now   Reply With Quote Quick reply to this message
Unread 05-16-2014, 10:13 PM   #3
pecos
This is the harness used..http://m.summitracing.com/parts/SUM-850520
My understanding was this has the diode installed, so the diode at alternator would not be needed.
