MSD Module - JeepForum.com
post #1 of 7 Old 10-07-2010, 10:29 PM Thread Starter
ozzieb
1977 CJ5
MSD Module
I just installed a 6a msd module on my 77 CJ 5. Teamrush installed a while ago. Today when I started it up there is a noticeable noise coming from inside the. Dizzy. Like a cricket. It does not stop. Runs great though. No problems. Does anyone else have the same noise?
ozzieb is offline
post #2 of 7 Old 10-08-2010, 05:36 AM
gojeepin
1983 CJ7
I'm running nearly the same setup without that noise.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 7 Old 10-08-2010, 08:07 AM Thread Starter
ozzieb
1977 CJ5
When I did the wires I ran them along my valve cover. With the rest of my loom. Could this be the reason? Interference?
ozzieb is offline
post #4 of 7 Old 10-08-2010, 08:39 AM
gojeepin
1983 CJ7
Did you twist your wires to keep them from picking up induced signals?
If the engine is firing properly I don't think that's a problem...
Your description of crickets inside the distributor sounds like something in the distributor is scraping.
gojeepin is offline
post #5 of 7 Old 10-08-2010, 08:49 AM
LSUtiger
1980 CJ5
That's what it sounds like to me also. Have you taken the cap off to see if there is something loose or the rotor touching?
Maybe the dizzy needs to be tightened down.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #6 of 7 Old 10-08-2010, 09:40 AM Thread Starter
ozzieb
1977 CJ5
The wires are twisted. I called msd. And I guess the trigger wires have to be away from all other wires. I will move them. And try that. Looked at dizzy.nothing touching. If it still makes the noise I will replace cap and rotor.
ozzieb is offline
post #7 of 7 Old 10-08-2010, 03:29 PM Thread Starter
ozzieb
1977 CJ5
I moved the trigger wires far away. Nothing With Votage is near them, still the same noise out of the dizzy. I Replaced the Cap and Rotor even though they are 2 months old. and same noise. I guess its just the noise the jeep makes now that it has a Real Module :-) Runs Great ! I left the Old Duraspark Wires In play Just For a Back Up.
ozzieb is offline
ICM module mjeckell Jeep CJ Forum 14 04-27-2014 08:22 PM
What is this module for weprint Jeep CJ Forum 6 07-07-2010 10:31 PM
MSD cdi module (which one?) kmm Jeep CJ Forum 17 06-17-2010 05:35 AM
Cj8 Module JEEPPARTSGUY Jeep CJ Forum 3 09-07-2006 09:21 AM
Ign module CJ-5 Jeep CJ Forum 20 09-28-2004 06:43 AM
