MSD ignition mounting location - JeepForum.com
post #1 of 4 Old 08-13-2003, 07:13 AM Thread Starter
possum398
I have just purchased a MSD ignition. I was wondering where would be the best location to mount it. If anyone has had problems with any locations please let me know. I was thinking of mounting it on the firewall, in the center. Any other sugestions?
possum398 is offline
post #2 of 4 Old 08-13-2003, 10:07 AM
JAX
Possum398,
If you are refering to the standard sort of ignition components (ie: coil, etc...) then just find a place up and away from direct engine heat (ie: exhaust manifolds, ec...). If you are talking about their upgrade modules (ie: MSD-6A, etc...) the same applies. Generally they give you a pretty long wire harness which will let you install it just about anywhere. Inner fender wells are a fairly good location. I'm planning to mount mine forward of the battery. One thing to keep in mind... If your Jeep has a computer - it is extremey important that you keep the main harness/power feeder away from your Jeeps wire harness and/or shield it. It will interfere with your Jeeps computer.
Good luck with your install. I haven't installed mine yet, but I'm looking forward to seeing what benefits it will provide.
Thanx,
Jax
JEEPNJAX
CJ8 - Longer Is Better...
JAX is offline
post #3 of 4 Old 08-13-2003, 11:15 AM Thread Starter
possum398
I was talking about the MSD 6A.
post #4 of 4 Old 08-13-2003, 12:32 PM
Sandman74
I have mine mounted on the top center of my firewall and have had no problems at all.
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
Mounting location suggestions for secondary heaters? texasimport Jeep CJ Forum 13 09-01-2009 01:55 PM
MSD-6A Mounting Location Ideas? JeepnBlake Jeep CJ Forum 17 06-26-2009 03:16 PM
New Ignition Box Location? scottymac62 Jeep CJ Forum 5 02-10-2009 08:40 PM
Gas Tank Mounting Location Hybrid Jeep Jeep CJ Forum 4 10-13-2008 08:01 AM
Negative Battery Terminal Mounting Location certifiablejeep Jeep CJ Forum 7 03-03-2004 12:38 PM
