MSD ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MSD ignition
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 05-06-2004, 09:54 AM   #1
Eddo
MSD ignition
I was looking at MSD CDI ignition box for my 258. However, I am wondering if it will make a noticeable improvement in idle quality and power. I have already done the TIFF upgrade and it definitely improved things.
So I read on some site that it makes a huge difference, but they where coming from a stock CJ ignition that is weak already. So maybe they would have noticed the same improved if they only did a TFI upgrade. I've also read that a MSD CDI box is useless unless you have a modified engine.
So do anyone have any experience with installing a MSD CDI box on an upgrade (TFI or HEI) jeep ignition. If so did it make any difference.
[b]81 CJ 5
03 KJ LE[/b]
Eddo is offline   Reply With Quote
Unread 05-06-2004, 01:48 PM   #2
CJay7
I have both the TFI and MSD 6AL ignition along with a Weber carb, cam, and headers. I didn't notice a big difference in the idle but I could feel a small increase in power during acceleration. There was a small improvement in idle quality but nothing big. I am also using the MSD Blaster 2 coil instead of the TFI coil. For me it was worth it because I was given the MSD for free (it was broke at the time but due to a mix up at MSD it was fixed for free all I paid was $9 for shipping). It also helped out with the rich condition that I kept experiencing. If you can find a good deal on one go for it, if not and your idle is good and you are not sure about it then put the money somewhere else for now. I would say the price you pay and the present quality of idle and fuel burn will determine if it is worth it for you. Mine was running very well to begin with so that could be why I didn't see as much improvement. I also prefer to have the rev limiter on there just in case.
Good Luck
'85 CJ-7 - 258 bored .030 w/ mid level cam, 4.0 head, Clifford intake and header, Weber 38, TFI w/ MSD 6, Black Diamond 3" lift, Daystar 1/2" lift shackles, 33x12.5 Goodyear Duratracs with stock 3.31 gears.
CJay7 is offline   Reply With Quote
Unread 05-06-2004, 09:42 PM   #3
Guy Hollister
Same question ... but with a HEI not a TFI... 258 with a weber carb.
g
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline   Reply With Quote
