Quantcast MSD ignition? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MSD ignition?
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 02-19-2007, 04:50 PM   #1
jeepsteads
MSD ignition?
anyone have installed one of these on their CJ... i just picked a brand new one up through a trade and was thinking about installing it.... is it worth it at all i know nothing about it really
jeepsteads is offline   Reply With Quote
Old 02-19-2007, 07:14 PM   #2
earlycj5
Works for me.
I'm happy with mine, V6 runs smoother with it, starts faster.
Try it and see for yourself. If you got it in a trade and you don't like it sell it.
regards,
Sparky
earlycj5 is offline   Reply With Quote
Old 02-19-2007, 08:24 PM   #3
Tumbleweed01
Mine works well in my 304. Smoother idle and faster starts. If you install it, pay attention to which coil you run-some are not compatible.
Tumbleweed01 is offline   Reply With Quote
Old 02-19-2007, 09:15 PM   #4
kbtriumph
You may want to read this thread before installing an MSD.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline   Reply With Quote
Old 02-19-2007, 11:28 PM   #5
jeepmor
It was a sound investment. Don't get it wet, or you'll be taking it apart and looking for blown traces. I did with mine, it's still running nearly 10 years after that dunk...and repair. It's hermetically sealed with silicone now too. BTW, the craftmanship inside is gawd awful hokey and looks like it was made by a stoned slacker high school kid. At least mine did. However, as stated, it keeps working fine.
If coupled with a Howell TBI, you will need a new filter in the Howell setup and a diode to your alternator regulator IIRC. The diode was for the MSD install and the vehicle would not shut off without the diode. It was in the MSD installation documentation. If you lack it, send me a PM and I'll go look for it if you cannot find it on the web. Be patient with me, I don't frequent this forum like I used to, but I'm always happy to help a fellow jeeper.
jeepmor
jeepmor is offline   Reply With Quote
Old 02-20-2007, 08:26 AM   #6
earlycj5
:shrug: There's a negative thread about everything out there. Stuff is bound to go wrong with something, somewhere to someone.
regards,
Sparky
Old 02-21-2007, 06:54 AM   #7
marmaduke
I run it and I can't fault it, I have a MSD 6al, coil and billet distributor, starts easily and runs and revs really smooth and very simple to install
'86 cj7, 360 cui, msd ignition, hedman htc's and still upgrading
marmaduke is offline   Reply With Quote
Old 02-21-2007, 08:02 AM   #8
CJay7
Mine works great. Starts, idles, and revs easily. You will need the diode otherwise it will not shut off, there are instructions for it, no big deal. I did leave my old ignition in place so if needed I can swap back to it if the MSD fails.
'85 CJ-7 - 258 bored .030 w/ mid level cam, 4.0 head, Clifford intake and header, Weber 38, TFI w/ MSD 6, Black Diamond 3" lift, Daystar 1/2" lift shackles, 33x12.5 Goodyear Duratracs with stock 3.31 gears.
CJay7 is offline   Reply With Quote
Old 02-21-2007, 07:01 PM   #9
bamacj
I have MSD stuff in my jeep and race car. No isues, good stuff.
bamacj is offline   Reply With Quote
Old 02-22-2007, 01:53 AM   #10
jeepmor
Only when it got wet.
Buy the vibration model which is filled with RTV. Or buy the 6al, breach the case, seal with silione or urethane, and move on and save a few bucks.
Old 02-22-2007, 05:38 AM   #11
marmaduke
Are you saying this was a bad place to put this?
If so where else do you suggest
Old 02-22-2007, 08:36 AM   #12
earlycj5
I just meant stuff in general. Heck, most folks like the 258 but I'm sure someone somewhere is ranting that their 258 is junk and no one should trust it. That's all I was saying. It doesn't matter how good something is, you can have 20 comments positive, I wouldn't weigh my decision on one negative.
Good advice. I think I may follow it.
regards,
Sparky
Old 02-22-2007, 08:43 AM   #13
Later_THANKS
Tried it and went back to a ACCEL coil.
I think the ACCEL works just as good.
Later_THANKS is offline   Reply With Quote
Old 02-22-2007, 09:16 AM   #14
earlycj5
It works in conjunction with a coil, it won't work without one. This statement makes little if any sense to me.
regards,
Sparky
Old 02-22-2007, 09:25 AM   #15
Mr.Crowley
1980 CJ7
If you plan on mudding it like your other pics,I would mount it inside and up under the dash....Just lengther the wires if needed...I run a full 7 digital msd on my 8 and havent had anyproblems with a 6al and some other msd products..They just need to be dry and kept somewhat cool..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Glock Forum
