Quantcast MSD coil question for team rush ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MSD coil question for team rush ignition
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 05-15-2009, 09:49 AM   #1
charliechicken
team rush mentions the msd coil 8205 do i need to install a ballast resistor also, as it mentions in the instrutions to do so with a ford duraspark ignition thanks again chuck
charliechicken is offline   Reply With Quote
Old 05-15-2009, 02:50 PM   #2
JeepHammer
Running On Empty...
1973 CJ5
Depends on what install you are doing....
Your '86 already has ONE reistor in place in the wiring harness,
You DO NOT need another one if you haven't cut the wiring up.
The easy way to test is...
Take a test light, Connect it to the battery POSITIVE,
Probe the battery NEGATIVE terminal and see what a 'Bright' light looks like.
Then disconnect the coil connector currently on the coil.
Turn the ignition switch to the 'Run' position,
Probe the 'RED' wire, look for a 'DIM' light.
If you get a dimmer light than you got testing on the battery, the resistor is already in place and you don't need another one.
The recommended resistor is for systems that DO NOT have a resistor already in place.
From '78 to '86 (and beyond) there was a resistor wire in place in the factory harness, and it's plenty for the coil I recommended,
No extras or replacements needed.
JeepHammer is online now   Reply With Quote
Old 05-15-2009, 05:25 PM   #3
genghisman
JH, I have a question about the resistor. I'm doing the teamrush on my 77 using majority MSD parts, including the coil mentioned above, just waiting for the parts to come in and start. Since I'll be using the resistor, is the diode that you recommended me to wire to my alternator still necessary?
genghisman is offline   Reply With Quote
Old 05-15-2009, 05:45 PM   #4
JeepHammer
Running On Empty...
1973 CJ5
What MODULE are you using?
'77 had a Prestolite module, and you CAN NOT use the Prestolite module with the Jeep/Motorcraft distributor...
*IF* you are using the GM HEI module, you DO NOT need an IGNITION RESISTOR of any kind.
(No matter which coil you choose)
*IF* you are using a CDI module, you DO NOT need an IGNITION RESISTOR of any kind.
*IF* you are using a Ford DuraSpark module (Jeep/DuraSpark)
Then you MUST use an Ignition Resistor to keep the cheap aftermarket 'Discount' modules alive.
At least 1.35 Ohms, and 1.5 Ohms would be better if you are using an E-core coil.
As for the DIODE...
The ONLY REASON you need a Diode in the alternator wiring is if your vehicle 'Runs On' after you turn the key switch off...
You *PROBABLY* will need a Diode if you are using a Ford/DuraSpark module, GM HEI style module, or an aftermarket CDI module.
BUT!
It will depend on which alternator you have now and *IF* it's got a stiff 'Brown' wire going to the #1 or 'R' terminal on the two wire plug...
If it is NOT a Delco Remy SI Series alternator, then you might not need a Diode...
Old 05-15-2009, 06:57 PM   #5
genghisman
I'm using the Motorcraft distributor instead of a stock prestolite. I do have the OEM alternator, and using the MSD 6a, Blaster 2 coil, and the required parts for the teamrush. My current dizzy is also a CRT HEI, so I don't have a module anymore, PO removed them.
Old 05-15-2009, 07:48 PM   #6
Rollbar
1984 CJ8
Hammer, if you lengthen the RED wire white stripe going to the coil will that change resistance or it doesn't matter after the crimp/connection in the wire loom toward the coil. I can just reach my coil but I would like to lengthen it to re-route it.
Thanks,
*MY CJ IS YOUR yJ's DADDY*
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote
Old 05-16-2009, 06:01 AM   #7
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Thanks,
No change with regular wire, you can run a few feet of it extra if needed.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 05-16-2009, 10:18 AM   #8
Rollbar
1984 CJ8
Thanks Mike, I do have a old harness I am using for things like this and I found the red wire w/the white stripe, I cut a piece of that & use it.
Thanks again,
Jim
Glock Forum
